GM HIGH TECH is looking for YOU!
Old Nov 16, 2009 | 02:47 PM
  #461
SIC LSX's Avatar
PERFORMANCE
Tuned in SD by Brian shell
Ls7 clutch
TSP 231/237 cam
Patriot dual gold valve springs on stock heads
TSP hardened pushrods
ASP UD pulley
Ported stock TB
LS6 intake
F.A.S.T Fuel rails
SVO 42lvs injectors
MSD plug wires
Pacesetter Long tube headers
TSP 3" off road y pipe
3" magnaflow bullet with turn down
SUSPENSION/CHASSIS
Qa1 coil overs with 325lbs springs on front
DMS rear lowering springs
UMI adjustable LCA's
UMI Relocation brackets
UMI sub frame connectors
BMR K-member
APPEARANCE
Panted ls6 intake silver
Painted coils red
Powder coated black sheet metal valve covers
VFN Wide Sunoco hood
Black tail filler with red inserts
Billet grill
Smoked headlights and turn signals.
Wheels
Convo pro 15x4 with 165/80's and 15x9's with 295/50's
Old Nov 17, 2009 | 06:16 PM
  #462
SILVERZZ28's Avatar
Made the readers ride.
Thanks
Old Nov 18, 2009 | 03:20 PM
  #463
CALL911's Avatar
Thanks
I think (even though it was never mentioned), that the readers ride section is all this is for.
Old Nov 18, 2009 | 03:33 PM
  #464
danbrazda's Avatar
2001 WS6 6MT, 450rwhp
ATR STAINLESS STEEL Cat Back Chambered Exhaust System.
SLP Long Tube headers with High Flow Catalytic Converters.
AFR Stage II High Flow Cylinder Heads. Comp valve springs,Titanium retainers, chromemolly pushrods,
AFR 228/228 Camshaft
Direct Flow High Capacity intake lid with K&N Filtercharger.
LS6 Composite Intake manifold.
GM Motive 4:10 Rear Gear.
Spec Stage 3 Ceramic/Carbon Clutch.
Eibach Sport Lowering Springs
BMR Struttowerbrace, Subframe Connectors, Adjustable Panhard Rod, Upper and Lower Control Arms.
18x9.5" Chrome Z06 Split Spoke Wheels w/premium BFGoodwrench KD tires. 275/35/18 on all 4 corners.
BAER ERADISPEED Drilled and Slotted Premium Brake Rotors.
B&M Short Throw Aluminum Shifter with Custom Billet WS6 shift ****.
Custom WS.6 Billet Race Pedals.
Old Nov 19, 2009 | 07:06 PM
  #465
chaman's Avatar
Just made the February 2010 Street Heat section! Thanks Justin!
Old Nov 19, 2009 | 09:06 PM
  #466
FASTFATBOY's Avatar
Where did you find this? Did you buy the issue? Is it out?
Old Nov 19, 2009 | 09:10 PM
  #467
chaman's Avatar
Im subscribed.
Old Nov 19, 2009 | 09:11 PM
  #468
Camaro396's Avatar
Old Nov 20, 2009 | 12:37 AM
  #469
MOE_TAWS6's Avatar
My car is in the february issue, I just can't find it anywhere!!! :/
Old Nov 20, 2009 | 09:20 AM
  #470
94capricelt1's Avatar
stock LT1 w/ 58mm nos tb(125 dry shot), long tube headders,chance built 4l60e w/ yank 3600 stall, new eaton posi w/ 31spline axles, on weld pro stars w/ 325-50-15 bgf dr
Old Nov 20, 2009 | 09:24 AM
  #471
Old Nov 20, 2009 | 04:11 PM
  #472
BADHAWK51's Avatar
I have the Feb issue and your car looks killer. They also got a shot of my car from the LTX shootout.
Old Nov 20, 2009 | 09:23 PM
  #473
MOE_TAWS6's Avatar
Preciate it man! and congrats on getting in it yourself too! now i just have to find it in a store!! haha
Old Nov 21, 2009 | 11:01 AM
  #474
chaman's Avatar
I saw that man!! Looks great!
Old Nov 22, 2009 | 08:28 AM
  #475
shawn_c992001's Avatar
Here are some of mine. Plenty more too.
Old Nov 22, 2009 | 10:01 AM
  #476
LS123's Avatar
It's on page 92 under "Mighty Moe"
I got mine in the old fashioned way, I sent it in via email. LOL
I have been subscribing since the GMHTP magazine was called just High-Tech Performance and had 6 issues per year! I think back since 1995. I still have every issue.
Old Nov 22, 2009 | 10:22 AM
  #477
Grn4fbody's Avatar
So do they tell you if your car gets put in the magazine?
Old Nov 22, 2009 | 10:28 AM
  #478
chaman's Avatar
Justin contacts you by PM asking for your full name and mods along with high resolution pics. Some months later the publication appears. In my case it took 5 months...but well worth the wait. The sensation of suddenly seeing your car is...quite good!
Old Nov 22, 2009 | 10:36 AM
  #479
matt427's Avatar
idk how to post pix but i have alot of good ones
Old Nov 22, 2009 | 11:19 AM
  #480
chaman's Avatar
Little help for you buddy...nice car!
