GM HIGH TECH is looking for YOU!
4.8L w/ Stock pistons, Rods, Heads, Intank manifold, TB
E85/Turbo/Nitrous/4l80E,A/C,Full Leather Interior/Towing Package
Won Southern Truck Shootout 2011 for fastest truck to "drive" thru the gate with a 10.67. Drove 11 hours round trip!
PB : 10.52@132.17 MPH
Ls1 Front End, Dash, and Taillights
383 Lt4 with Lloyd Elliott Top End Package (homebuilt motor)
3600 stall w/ Built 4l60e
Moser 9"
Nitrous
600+rwhp
Last Picture is of me and a current street heat Trans Am..
Location Benton,LA
-Tuned by Todd@Blue Thunder2 Racing
-Pic by Daniel Carnley
-fully forged 382 stroker,
-fast 90/90
-tsp pro 2.5 heads
-kooks 1 7/8 header
-meizier electric water pump
-slp lid
-turbo 400
-3500 yank converter
-b&m billet slim line shifter
-BMR torq arm
-BMR subframe connectors
-BMR upper lower control arms
-strange adjustable coil overs
-Quick perfromance 9" 390 gears with Yukon third member ---moser 31 spline axles
-4" mufflex exhaust
-edelbrock 71900 nitrous controller,double nano competition system
-cold fusion nitrous plate
-wolf mini tubes
-custom weld in rear anti roll bar
-custom 6 pt cage
-leather ws6 electric seats
-cold a/c and power windows
-billet specialty street lites
Car has been 9.81 at 139...60' was a 1.39... Drive it all over town and to THA track on race days.
For those of you who have posted and haven't been chosen, we've had to leave a couple of cars out due to photography. First and foremost, please make sure the ENTIRE car is in the frame and in focus. Nice bright lighting is also good. Most importantly, make sure your car is on concrete and NOT GRASS!!
Also, post specs... A car with no information just won't cut it.
Thanks everyone, this is a great thread and we appreciate every single person that has posted so far!
2000 Hardtop SS
LS3 with Texas speed 231/273 cam
th350 with 4000 converter w/break
Texas speed 1 7/8 long tubes
Texas speed True duals
Moser 12 bolt
Billet Specialties w/325 Drag radials
tubular kmember and upper and lower a arms
midwest TA and LCA and PHB
Still got to put Berger stripes on and mini tub it
Photos:
2003 Chevrolet Corvette ZO6 50th Anniversary
-LS3 short block
-LG Motorsports G6X3 camshaft
-TrickFlow 235 cylinder heads, milled 0.040" (11.68:1 CR) w/ powdered metal valve guides and custom exhaust valve sizing + some anti-detonation work to chambers (compliments of Brian Tooley)
-TrickFlow Platinum valve springs w/ titanium retainers
-COMP Cams hardened pushrods
-COMP Cams trunion upgrade kit
-LS7 lifters
-Melling 10296 high pressure/high volume oil pump
-Katech C5R timing chain
-ATI super damper (10% underdrive)
-McLeod RST twin disk clutch
-Tick Performance clutch master cylinder
-Tick Performance remote speedbleed line
-LG Motorsports Pro long tube headers (no cats) - stock Ti exhaust
-FAST102 intake (port matched by B. Tooley)
-Siemens DEKA 60lb injectors
-Vararam VR-B2 ram air intake
-Vararam power duct
-LS2 90mm throttle body, with 90mm ring on intake - hand polished ID
-Racetronix fuel pump hotwire harness
-Racetronix cam sensor harness
-Racetronix knock sensor harness
-Racetronix throttle body harness
-EFI Live tuned (Tracy Scott + Kevin Doe)
-HSW Sudden Impact dry nitrous kit
-CCW Classic wheels 18x9.5 front, 18x11.5 rear
-Toyo RA-1 tires 275/35 front, 335/30 rear
-MGW short-throw shifter
-MGW shift ****
-Sparco Torino racing seats
-Simpson 5pt harnesses
More for your own edification... engine build and wheel restoration threads...
http://forums.corvetteforum.com/c5-z...-and-such.html
http://forums.corvetteforum.com/whee...storation.html
