GM HIGH TECH is looking for YOU!
Old Mar 2, 2011 | 04:02 PM
  #701
SIC LSX's Avatar
Thanks a lot justin cant wait!
Old Mar 10, 2011 | 12:14 PM
  #702
Deeavi's Avatar
Default couple quick pics
300 MPH Duct Tape:
Old Mar 10, 2011 | 12:36 PM
  #703
Ellsworth's Avatar
Bought this car for $500 when I was 15..
totally transformed it in the last 3-4 years through highschool.
1998 Firebird 3.8L to LS1 swap, Mild Cam, headers, LS6 Intake, lid, bmr suspension, wheels, cloth to leather interior, custom stereo, wheels etc.
Love this car put all my hard earned pennies into this thing.
Old Mar 10, 2011 | 05:42 PM
  #704
TWOBUELLS's Avatar
Default 2010 Vettes for Vets , @ Talladaga
Old Mar 13, 2011 | 01:46 PM
  #705
Grn4fbody's Avatar
Old Mar 13, 2011 | 02:59 PM
  #706
Texas_LS1's Avatar
Default My H/C/I ws6..:)
Here is mine
Old Mar 14, 2011 | 05:28 AM
  #707
xXxSilveradoxXx's Avatar
Originally Posted by Deeavi
Forgive my ignorance but what is that cog belt running?
Old Mar 14, 2011 | 06:49 AM
  #708
Deeavi's Avatar
It is a GZ Motorsports vacuum pump! I really needed it on my last LS motor which had a good bit of blow-by. The LSX has none. The pump works. It creates a vacuum in your crankcase that helps with ring seal and horsepower.
All I get out of the LSX crankcase is some clear liquid that smells almost like turpentine or paint thinner? I think it is vapors mixed with condensation.
Old Mar 15, 2011 | 01:40 AM
  #709
Weskot's Avatar
2000 Camaro SS. 38k miles. Only mod is k&n air intake. Future mods will be full suspension, subframe connectors, performance brakes, etc... Focused on Spirited Daily Driving & Autocrossing.
Old Mar 15, 2011 | 06:00 AM
  #710
cbloveday's Avatar
I am in the process of the an engine swap for my 2009 cts-v
Callies dragon slayer crank, sent out for
swain coating, xray for stress. extra material
removed to save weight Forged with 4.0
stroke
LSX racing bl... LSX racing engine block, sent out for xray
after final bore, magnufluxed, checked for
any flaws, extra material removed.
Callies 1500 i... compstar I beam rod forged 1500hp+ 4340
material with ARP upgraded bolts sent in for xray
Wiseco 4.155 bore -23 cc supercharged
pistons with gas relief ports, weight
reduction, valve clearanced for ls7 head,
sent off for piston coating for high heat/boost/ nitrous levels.
GFX rings High powered nitrous/high boost ring set for
4.155 bore pistons
Arp main studs for lsx block HD for 1500hp
New Melling high volume high pressure pump with
25% more volume than stock lsa
durabond Racing Cam bearings for lsx block
ACL rod bearings, High output load acl bearings
ACL main bearings, Main bearings for standard bore
compcams magnum LS7 style 3/8" pushrods
larger diameter for higher spring pressures
Fully CNC ported LS7-based cylinder heads! (All New GM LS7 Cylinder Head Castings or Performance Inductions 6 Bolt LS7 Heads).700" Lift Double Spring Kit, 2.250"/1.61" Titanium Intake\Stainless Exhaust.
Cometic 4.16 head gasket copper engine assem... blueprint, assemble Lsx racing engine to exact racing specs.
New flexplate... 6Bolt hd flex plate for 6l90e trans to mate to
dragonslayer 58x with 6 new bolts
ls7 to ls3 intake. Mates ls7 heads to lsa intake design ls7 head part kit contains lash caps for titanium valves, ls7 specific rocker arms at 1.8 ratio, rocker arm
bolts, spring locators, and upgraded valve
seals.
Nitrous direct port up to 400 shot.
If you are interested, pm me.
Old Mar 15, 2011 | 11:41 AM
  #711
THADD's Avatar
1997 LT1 Camaro(HITMAN)tagged and insured with current inspection 9 sec car
383, forged bottom end, Trickflow heads, custom cam, built by Dusty at BHP, Tuned by Jeff at Mayhem Motorsports, Moser 12 bolt, Spoon TQ arm and LCA, UMI subframes QA1 coilovers, 6pt cage, Kirkey seat, NX kit with fuel stand alone, TH350 4000 Vig stall, blah blah lots more...runs low 6's in the 1/8th and high 9's in the 1/4 and can be driven in the street at any time
Old Mar 15, 2011 | 08:49 PM
  #712
maxplusten's Avatar
Few of the sled, shes not back together yet but will be within the next month:
Old Mar 24, 2011 | 11:07 PM
  #713
Tall Guy's Avatar
Hey Justin
A couple of pix of my HOSS with the LPE top end kit.
There is also a good story with this car also.
Old Mar 25, 2011 | 01:19 AM
  #714
Sommer86's Avatar
WOW! I effin' LOVE the color!
Old Mar 25, 2011 | 04:48 AM
  #715
HartAttack's Avatar
2002 Firehawk M6 Vert. 1 of 26.
Located at Hickam Air Force Base Oahu Hawaii Come on GM High Tech!
  #716
HartAttack's Avatar
Old Mar 25, 2011 | 11:17 AM
  #717
maxplusten's Avatar
Thank man! Medium quasar blue
Old Mar 25, 2011 | 11:58 AM
  #718
Johawk's Avatar
http://i38.photobucket.com/albums/e1...techgmht-1.jpg
You deserve a lot of credit. I know GMHT is full of 4th gens but Im a fan of the little guy triumphs. Makes for a good story. You have some nice pics too.
Also, I always loved quasar blue.
Old Mar 26, 2011 | 10:30 AM
  #719
PontiacTransJB's Avatar
Default my 04 z16
this is my 04 z16 stock as they come. and you can get a peek at my 02 ws6 with bolt-ons.
Old Mar 26, 2011 | 07:15 PM
  #720
Black94Z28's Avatar
Justin-Sent you a PM about my Camaro a month or two ago...Anyways, Camaro is always changing. My 94 LT1 Camaro "SS" with a LS1 front clip, wheels, spoiler, interior. Get ahold of me if you need better pics or more info...
