EPS cam idle video
Good insight. I hope to get hptuners for my ride at some point. But at the moment, it is more cost efficient to have it tuned for my build configuration. I have a good knowledge of EFI principals (went to school for it, and have done a good bit of troubleshooting) and mechanics, so once I learn the software I don't think i'd have too much trouble. Although, tuning and viewing/troubleshooting EFI data are 2 different mindsets- so there will definately be a learning curve of some sort.
Good luck to you on procuring some leads for tuning other cars.
www.bakerengineeringinc.com They are a sponsor on here too.
My idle is set to 900 rpm and with the cut out open it sounds like a drag car haha. Throw that cutout on and it will wake things up, too bad they sound like **** driving around and rattle the hell out of everything in the car. Believe it or not I have my car dialed in to idle as smoothly as possible, flow matched injectors, dialed in over/under speed spark tables, open loop speed density tuning, 15.2 AFR (most crisp), proper timing, raised idle rpm and proper base running airflow. Last edited by Nitroused383; Feb 19, 2010 at 07:08 PM.
Really close to XE-R specs with subtle differences, lift is less too.
.006 - .050 = 49*
.050 - .200 = 80*
Amazing what you can find when you properly use the search button!
http://www.youtube.com/watch?v=8swrzihvJqY
http://www.youtube.com/watch?v=5mwLwUnGFYY
http://www.youtube.com/watch?v=jJ116aXyt8g
Who tuned it for you? I'm in SE Michigan. Won't be ready for a while, but I'm just wondering who did your tune.
Put 3.750" PR's in at first (set @ .088" preload) with the LS7 lifters and wasn't happy with the harmonics.... just recently put in a set of Manley 4.00" PR's (.113" preload) and it's quieted down a bit, but still not to stock levels, but not very noticeable.
Tuned by Geoff at EPS via mail order. I wanted good driveability first and foremost since this is my DD. I know there's still some power left on the table just by nature of the mail order method, but she drives smooth without any issues. I'd rather be slightly down on power and not have to deal with bucking/surging/stalling. Who better to tune the car than Geoff @EPS who designed the lobes and spec'd it as well as experience tuning that cam in person on a dyno. Geoff is a top notch guy and runs a top notch performance shop. Once I get some more mods i'll get a dyno tune.
