cammed 2011 mustang!
Mustangs Daily
COMP Cams has become become the first in the industry to offer aftermarket camshafts designed specifically for the 2011 Ford DOHC 5.0L Coyote 4-Valve V8. The new billet hydraulic roller cams from COMP Cams unlock a major power upgrade for the 2011 Ford Mustang 5.0. Designed specifically for Coyote V8 applications, these camshafts are counter balanced and work with phaser limiters to produce optimum safe power.
The gigantic lobe size on the Ford OHC is unlike any other cam-in-block engine, and the dangerous harmonics that come with the giant lobes must be addressed for high performance usage. By taking cutting-edge race technology and applying it to street applications, COMP Cams has engineered these new phaser-friendly cams with an exclusive integrated counter balance design that cuts down on vibrations and reduces overall harmonics to ensure a smoother operating valve train that was properly engineered for high lift, long duration valve motion at high RPM.
These newly engineered Ford 5.0 camshafts are available for both naturally aspirated and supercharged engines, with three stages available in each series, as well as custom grind and No Valve Springs Required versions. Optimized race and street profiles give you the power where you need it most, whether that’s maximized mid-range power and torque or increased top end horsepower. Custom racing profiles are also available for high-performance circle track and drag race applications.
For more information about the COMP Cams® 2011 Ford DOHC 5.0L Coyote 4-Valve V8 Cams or any other COMP Cams® product, call 1-800-999-0853, or visit www.compcams.com.
it sure does sound odd though whatever "it" is.
Would love to hear that at full tilt!!
The cammed car is a 3v with BBR cams (05-10 GT) with the 5.0 parked there just to get a reaction. There is a shop testing cams currently though and results should be posted shortly.
Cams are ~899 dollars which wasn't as bad as what I initially thought.
