Ren's cam only camro runs 10.06 @136mph vid
Have you thought of trying 4.10's when your on the bottle?? Ive seen some cars drop from 4.10s to 3.73's on the spray in their 9inch @ the local 1320 and do alot better than 4.10's on the bottle. Just a thought tho, theres alot more factors coming into play to compare BBC stuff to LSx stuff anyways. Since your on a 9inch the gear swap should be pretty damn easy anyways.
I am goin through around 6800-7000 I dont have a true reading yet as i was not logging those passes, and I am running 28x10.5's m/t I really dont think switching to a taller gear will help. clutch cars are kinda funky, If I go 4.10's or 3.90's I feel like it will either bog or spin way more... We will see I dont mind making small changes to my combo.
The shocks are afcos with stock springs in the rear and strange single coil overs up front with 275lb springs.
yeah when ya run cam only your down on torq so u need the gears to get it off the line! my car feels so much better then it did with the 3.42's lol
#33
Rob
#34
thanks guys! I Don't have any type of progressive system on my car. It is just a solid 150 shot off the line(if thats what you were asking). Air fuel is around 12.2 now which I don't really want to push that much more. I have thought about doing a vic junior set up seems like it would pick up quite a bit...
Rob do you run subframe connectors?
#36
#37
I have never put any on my car, but people in general are in disbelief when I tell them I am not running sfc's. But since the wolfe bar I havent noticed it tweaking to the right any...
#38
I would say it is what you want out of your car. I think at this point there are some better cams out there. I have heard ALOT of good stuff about Geoffs cams at eps making great power with out sacrificing to much down low. However you can pick up a trex used for cheap and you WILL make power!
