Vid inside-how slow is my bone stock 99 T/A
Wheels spin free, verified that checking gear ratio in the driveway. I have access to lifts 24/7 so I figure I can run open manifolds for a short time to see what it acts like. I'm hoping its the clogged cat thing, that millisecond when you put your foot down it acts like its gonna take off and then its just got nothing. Its hard to put into words without feeling it I guess.
Another way of checking the cats is with a laser temp gauge. Before temp/After temp, Left temp. vs. Right temp. If there is an issue it should be creating loads of heat in the cat.
Also when i had my 2.72 Z28, I swapped in 3.42's, lid, and catback. Holy crap it was like a whole new car! I also went through 2 sets of cats on that car when it was bone stock, It would fall on it's face and sound like a helicopter.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
first i read all the comments then watched the video and im blown away that was slow. I sware the 2001 bonneville SSEi 3.8L S/C would give that a good run i had years ago.
That engine is missing a ton of power. Probably 100+hp.
Don't bother with the exhaust. If one or both cats were restricted you wouldn't be able to spin the engine up as high as you did in the video. You would hit an RPM wall, like a soft rev limiter. Usually in the 2500-3500RPM range.
If you had low compression or a misfire, you'd probably notice that at idle.
You've got either a bad/contaminated MAF or the PCM is pulling timing (false knock, poor fuel delivery, etc). Cleaning the MAF is part of a modern tune-up.
Captain Double Post
I agree with post above, i really dont think its a exhaust issue,like i said a compression test/leak down doesnt cost alot of money, if that was my car that is the first thing i do, then once that was ok i would go down the list, that car has some kind of issue, i mean thats close to stock 2v territory
Marc 85Z28, thanks for you're input and I believe you may be on the right track. I pulled drivers side cat today and it was perfect. The motor runs perfectly smooth at all rpms so no mis-fires but could it still be low compression? Uses no oil and plugs look great, as does coolant/oil.
I did clean the maf when I tuned it up, forgot to put that. It had lots of dust/small rocks stuck in the screen. Hosed it all down with electronics cleaner and cleaned the screen out with fine wire. It has a tick in the motor at idle but that's the only time you can hear it. Could that be enough to cause false knock? I need to identify it though. Checking fuel pressure should be my next step and its easy.
lmao. the whole time i was reading the thread (before watching the video) i was just hoping... i hope its not faster than mine. mine feels pretty slow, not sure if its because im just used to it or what.
#32
^x2 lol I was like damn I think mine feels slow, but yeah you defiantly have a problem, when mine was stock with 2.73s it was still a lot faster then That, run a compression test and post up the results
#34
#35
Its the maf, unplugged it and the idle cleaned up even more. Jumped in and noticed it even after just putting it in gear and rolling out of the driveway. Then I made this quick vid. Off to find a new MAF! Anyone who's been following this got any handy?
![](http://i193.photobucket.com/albums/z286/fishnugget180/th_2012-06-05_13-01-45_754.jpg)
