No cams in the future
Old Feb 21, 2013 | 08:59 PM
maxgee's Avatar
Default No cams in the future
Seems like good things ahead
Old Feb 21, 2013 | 09:54 PM
LEO's Avatar
LEO
The future seems like it will be getting a bit faster and lighter.
Old Feb 21, 2013 | 10:43 PM
Cajun ELESS-ONE's Avatar
Old Feb 22, 2013 | 12:43 AM
t_raven's Avatar
There have been similar designs for decades. There's even a thing called a barrel valve which eliminates standard poppet valves.
I'm curious why they would use air rather than high pressure oil. From the designs I've seen, a set up similar to a diesel injector using high pressure oil to open the valve is probably the best option.
Hopefully somebody makes this practical in the near future so we can see what it can do.
Old Feb 22, 2013 | 10:03 AM
89gmcs15's Avatar
When I was 13 my dad and I took a road trip and along the way we got to talking about engines. He told me bak then the ideal engine would have a air powered or solenoid valve to open and close the valves. He said the problem would be the computer technology to control it at high Rpms. Looks like they've figured it out
Old Feb 22, 2013 | 10:45 AM
samckitt's Avatar
Doesn't F1 engine use electromagnet actuators for valve actuation now?
No more cam swaps, just reprogram it to open the valves at different times, heights, etc. Could then be programmed for different valve timing/lifts etc for different RPM ranges.
Old Feb 22, 2013 | 11:32 AM
SSickLS1SS's Avatar
this is simply amazing
Old Feb 22, 2013 | 12:32 PM
jbridwelltransam's Avatar
really cool to see stuff like this happening. I was just thinking of how the internal combustion engine hasn't had any major radical changes in a while.
Old Feb 23, 2013 | 10:07 PM
96z28_lt1's Avatar
pretty awesome, think about your engine with several different settings you could probably select. tune a very streetable good gas milage setting, get to the track load you other valve setting and haul some serious ***
Old Feb 24, 2013 | 08:43 AM
TonyGXP's Avatar
great video, thanks for sharing..
Old Feb 26, 2013 | 01:03 AM
HoLLo's Avatar
That's pretty amazing. Imagine a turbo on that!
Old Feb 26, 2013 | 03:53 PM
Turbo_Stang's Avatar
Sounds like endless cam options in the near future
Old Feb 28, 2013 | 06:09 PM
92 silverado's Avatar
thats pretty cool
