Magnacharged TA dyno
Old Nov 7, 2007 | 05:38 AM
yotaman96's Avatar
Default Magnacharged TA dyno
I only had a crappy digital camera, but at least you can hear what it sounds like. These runs were still in the tuning phase and hp #'s were in the 490's. Ended up with 510/497.
Old Nov 7, 2007 | 06:07 AM
2001z's Avatar
sounds good man! I love the way the charger sounds
Old Nov 7, 2007 | 09:14 AM
robster's Avatar
awesome
Old Nov 7, 2007 | 09:25 AM
Medic/Z28's Avatar
Could we get some more pics of the charger on the motor. Did you have to cut anything on the top of the firewall to fit it? I thought it wouldn't clear. I wonder if it would work on camaros? I perfer screw type chargers over the centrifical ones. Thanks in advance for the pics.
Old Nov 7, 2007 | 11:44 AM
Razorsedgepit06's Avatar
Cool vid, never heard a maggie on a T/A before. Thanks for sharing
Old Nov 7, 2007 | 12:11 PM
redsilverado05's Avatar
Awsome, looks like it put down some good numbers. I bet that thing pulls like hell on the highway. What other mods do you have besides the magna charger. Oh yeah, how about some ET's.
Old Nov 7, 2007 | 12:14 PM
00Formula00's Avatar
Wow, I kinda want a magnacharger now... AWESOME MAN!!
Old Nov 7, 2007 | 01:03 PM
big reg's Avatar
What size pulley are you running and how much boost?
Old Nov 7, 2007 | 02:53 PM
yotaman96's Avatar
Yes you have to cut a little on the cowl. Nothing noticeable once the plactic cover is put back on. The k-member is also slightly lowered. Check out Late Model Speed for the kit. They are a sponsor here. Here's a link to some pics of the install. Make sure you look at both pages.
http://s28.photobucket.com/albums/c2.../Magnacharger/
Old Nov 7, 2007 | 02:54 PM
yotaman96's Avatar
TR224 cam, TEA stage 1.5 heads, 123,000 mile stock bottom end. Ran 11.4 @ 122mph with a slipping clutch.
yotaman96's Avatar
Pulley is now a 3.2 and I get 6-7lbs of boost.
Old Nov 7, 2007 | 04:33 PM
2000Hawk's Avatar
Gotta love the sound of a magnacharger, get us some vids of it on the road.
-Joel
Old Nov 7, 2007 | 04:35 PM
mthegodfather's Avatar
Sounds awesome.
Old Nov 7, 2007 | 04:43 PM
Medic/Z28's Avatar
Looks good.
Old Nov 7, 2007 | 06:18 PM
allthrotle's Avatar
What are you doing for fuel? what size injector 42lbs? what size fuel pump?
Old Nov 8, 2007 | 03:26 AM
yotaman96's Avatar
I run 93 octane all the time. The car has a Walbro 255 fuel pump, 42lb injectors, and the magnavolt. Since I already had the Walbro 255, I probably didn't have to have the magnavolt. The injectors are at 102% duty cycle.
Old Nov 8, 2007 | 03:27 AM
yotaman96's Avatar
-Joel
Have to replace my clutch first and buy a camcorder.
Old Nov 8, 2007 | 03:43 AM
BrokenTA's Avatar
Is your hood modified at all? You mentioned modifying the K-member, is that the stock one or do you have a tubular? cutting? welding? fabricating? Oh and one more thing.. that thing is F'n SICK!!
Old Nov 8, 2007 | 03:57 AM
yotaman96's Avatar
Yes, I did cut my hood to make it fit. Some people may not have too. I probably could have ground down the throttlebody some, but I decided to cut the hood instead. The K-member is stock. Just added spacers and longer bolts. The only cutting is on the cowl close to the windshield wipers. It's covered by the plastic so no one will notice.
Spacers for the K-member.
Marking the cut on the cowl.
Cut I made on the hood.
Don't worry, you can't see it.
You can see the cut after I welded a plate in and painted it here.
Old Nov 8, 2007 | 04:26 AM
bad95killer's Avatar
very nice .. sounds good
