Need Help With Corvette - Video Inside
Old Sep 9, 2003 | 02:04 PM
Will Clark's Avatar
Default Need Help With Corvette - Video Inside
So a while back my dad swears he's hearing this cracking noise, I listen to it and you can distinctly hear it coming from the back left. Not only that, but you can sometimes see the wheel move a little when you go back and forth. In the video you can hear the transmission shift, then when it pulls in either direction you hear a *crack/crunch/pop* kind of sound, I swear its like a U-Joint.
http://webpages.acs.ttu.edu/nschrein...te-problem.MPG
I took it up to my work to get it checked out and they believe its a U-joint as well, but thats a pretty expensive guess. Also when you shift easy from 1-2 it shakes sideways for a couple seconds, anything to do with it? What do you think about it?
Old Sep 9, 2003 | 05:59 PM
PendragonZ's Avatar
Chop-Foo Director
Default Re: Need Help With Corvette - Video Inside
Hrm, I hear it, but don't know what it is.
Doesn't sound good tho.
Old Sep 9, 2003 | 06:45 PM
Will Clark's Avatar
LOL, then its a damn good thing I don't have to pay for it! :p
Old Sep 10, 2003 | 04:18 AM
Chris D.'s Avatar
Sounds dumb but, make sure the lugs are tight.
Old Sep 10, 2003 | 10:35 AM
Will Clark's Avatar
They are, I torqued them down myself to 95 pounds.
Old Sep 10, 2003 | 08:09 PM
UGOT8's Avatar
thats what my car sounded like when the main bearings where going out in my rear .. but it could be something else too
Old Sep 10, 2003 | 10:37 PM
Will Clark's Avatar
Anyone else? I need ideas here, anyone wanna explain the 2nd gear shake?
Old Sep 11, 2003 | 02:21 AM
Screamin_Z's Avatar
that's my guess, the bearing.
Old Sep 11, 2003 | 09:29 AM
Fbody Man's Avatar
ur trans could be on its way out. When i used to work at the dealer i had that prob. with a car. It made a sound in the drivetrain. It turned out to be the trans. just check it to make sure. Look at the fluid.
Old Sep 11, 2003 | 11:06 AM
Will Clark's Avatar
Some guy on the corvetteforums said his was doing the same thing and it was the hub assembly. What do you make of that?
Old Sep 11, 2003 | 01:30 PM
gMAG's Avatar
I'd jack up and support the rear, pull the rear tires, then go through the backward-forward thing. You'll have a better "see" at where exactly the noise comes from. For extra safety, I prefer a stack of nailed together 2x8's under each side of the frame in addition to jacks.
Old Sep 11, 2003 | 03:50 PM
Will Clark's Avatar
I had it on an alignment rack and did that. Everything was solid behind the wheel save the caliper which is one more thing to look at. I was never there when they ran it with the wheel off.
Old Sep 13, 2003 | 10:10 PM
gMAG's Avatar
Does the noise increase with speed? Does it correlate with the rotation of the tires, or driveshaft? I can't tell from the video.
You've probably already checked this, but it doesn't hurt to ask.
Old Sep 14, 2003 | 02:50 PM
Will Clark's Avatar
I've talked to C4 Corvette owners whom have been through this, they all seem to think its the outer U-joint. It would explain why I also get the 2nd gear shake. At $20 a piece it will definitely be the first thing I'll do, even if it does take 3-4 hours for both sides.
The noise doesn't increase with speed and you can hear it every once in a while when you drive, usually when you hit a bump around a corner or something. It doesn't increase with with tire rottion and everything seems to be tight.
Old Sep 14, 2003 | 03:14 PM
gMAG's Avatar
Here's to the $20. parts (and some elbow grease)!
Hope all works out the way you intend.
