cam question
mods: slp flow pac, slp catback, stock ls1 manifold (for now, LS6 is in the works) ported TB, TB bypass, de screened MAF
TIA!
you can buy a better cam with the added lift already ground in.
something with near stock driveability and sound (like the ls6 would give) would be the cheaTR cam or some of the stealth cams (mti i think).
with your mods, and the ls6 cam...i would expect about 360rwhp give or take.
with a cam such as the 224 you could make 380rwhp no problem...and not have to spend $400 on rockers.
yes a cam will benefit from a higher stall.....HOWEVER...a stock engine/cam will benefit from a higher stall as well.
if you keep the cam mild, you can still run the stock stall. the car may not be optimized but it will still run well.
the cams suggested should all work with stock stall, however you WOULD benefit from a new one.
stock cams were in the 19x/20x range....even stepping up to a 224 is still considered mild, moderate is in the low 23x range, and big is upper 23x's or even 24x's.
yes there are several 224 cams, but they are pretty similar. generally they produce similar power. theoretically the one with the higher lift should produce the best numbers. i'd look into thunder racing or TSP.
https://ls1tech.com/forums/generatio...cam-guide.html
It helps to read over that a couple of times, seriously.
IMO just switching to a LS6 cam isn't worth the trouble. Plus you see them in here for cheap all the time so if I was gonna get one it wouldn't be from Summit.
I would definitely do stall too before the cam. A stall will make even a stock car faster
We ran a cam special a few months back that included the cam, springs, pushrods, gaskets, timing chain, install and dyno tune for $1700, and around $2100 with dual springs, oil pump, and dual roller timing chain.
