traction issues
as of right now my car just has full exhaust with dual cherry bombs, headers, and a cam, if that helps any
Lower control arms will help you launch better and stop wheel hop. You could also do a panhard bar and torque arm to help put the power on the ground. Check out www.spohn.net they have alot of good suspension parts
im in the same boat as sweetsolace
on my old bolt on LT1 i had the crappiest tires in the world...but i had several of the suggested suspension mods also....i could chirp 4th on occasion.
swapped out to some GOOD tires (still 245s) and never heard a chirp beyond 2nd gear after that.
sounds like you need tires more than suspension.
i have 17x11 rims on my cammed car now. and they cam with worn nitto DRs. i recently upgraded to the Nitto 555r street tires and traction is almost the same. they are truely awesome tires. and cheaper than many of the high end competition.
if you plan to lower the car, make sure to get the relocation brackets.
Added a torque arm, and adjustable QA1 shocks on the rear, and now it will leave on just about any tire I toss under it street or strip. On motor, i can do 1.8x 60s on my 215/60/15s, yes 215's! (best pass was 12.0 @ 117 on the street tires)
My advise, get some good rubber if you can afford it, and afford replacing it as you wear them out.
If not, get the torque arm/shocks/LCAs/LCARBs in that order, unless you have wheel hop, then get it all.
either that or the wheels are hitting the inside of the fender.
run your finger around the inside of the wheel...if they hit the fender....clearance it.
lowered 2" is gonna make traction hard to get. lowering a car is one of the worst things you can do for straight line traction.
and you can run what ever tire up front. This is what I have only in a 17". You'll probly see that you will change the rear out 2 times before you need new fronts. http://www.discounttiredirect.com/di...%2FPerformance Ask about the size for some reason I cant find the size I have but my fronts are now a 275's wide over the stock 245's and with the 315's in the back it goes around turns like its on rails. whether a wheel will fit or not depends on the specs of that rim. width, backspace, offset...etc.
given the right rim setup, a 315 WILL fit under the rear end, but if you're lowered you may have more clearance issues.
