Any ideas or mods to help my setup. I'm all ears!
Hi all! Got a 99 T/A that I just drove outta state to pick up a Ram Air Hood for. I have the Volant Air Box (only they sent the single oval-shaped filter one for the Camaro instead of the dual filter one for the T/A from Volant). Since the hood itself acts as the lid for this setup, I've been playing around with the idea of making the hood fully functional by removing the baffle, but then the air and rain will be hitting straight onto the air filter it would seeem... Any ideas on how to get the hood to perform best with my setup? I also have been having a little trouble lining up the Suncoast Ram Air hood. I got it very very close through adjusting hod bolts and the black rubber bumpers in the engine bay, but it still shows slight gappage (maybe a 1/4") between the front bumper and the hood and about an 1/8" gap between hood and lights... Any ideas on that would be appreciated as well. Thanks all!
Oh... also... I saw someone who was having the typical "my idle on my tach is perfect, but the car has a slight rough idle shake to it" problem on another thread and someone said to clean the Air control motor or something located on the top driverside of the throttle body. What are they talking about? L8r all.
Wasn't hard to do. Not sure if it quite improved things yet as I haven't driven it, but it was easy to do and couldnt have hurt anything to get all that carbon buildup off. Thanks for the heads up on that!
That was probably me and I was talking about the Idle Air Control motor. It is attatched the throttle body. On top of the drivers side. Unplug it and remove it from the throttle body. It is probably all carboned up. Use brake clean, throttle body cleaner, even wd-40 works to clean then gunk off. Then re-install the IAC and your done.
