Is a radiator from a 98 interchangeable from an 02
Old Jan 5, 2009 | 10:07 AM
Juicedz28's Avatar
Default Is a radiator from a 98 interchangeable from an 02
I would like to know if a radiator is innerchangeable from a 98 to an 02. i ran into a slight problem and would like to skip jb welding it if i have a useable unit. thank you.
Old Jan 5, 2009 | 11:51 AM
9000th01ss's Avatar
Yes, the only difference would be with or without trans cooler. And I've seen some with coolant level sensors, if you don't need that let it plug the hole.
I'm pretty sure they interchange back to the LT1 models.
Old Jan 5, 2009 | 01:37 PM
ibmotors's Avatar
The only differances are with and w/o tranny cooler and/or coolant level.
The LT1 style is different It has one extra line on one side and missing one on the other.
Old Jan 5, 2009 | 01:42 PM
the_merv's Avatar
Veteran: Air Force
The LT1 one will work without a problem, ask me how I know..
You just have to cap the spot off on the lower Driver's Side, there is nothing missing, just that extra Hose that goes into the LT1 Water Pump.
BTW, the LT1 Radiator is actually better than the LS1 Radiator.
Old Jan 5, 2009 | 01:48 PM
dschmittie1's Avatar
I think a 98 radiator has a level sensor and the 02 doesn't that would be the only difference. so it you have the level sensor with the rad just leave it on there.
Old Jan 8, 2009 | 12:29 AM
demonpixel's Avatar
What about vice-versa? Will a 98-02 fbody radiator fit in a 93-97 fbody?
Also, why is an LT1 radiator better?
Old Jan 8, 2009 | 10:05 AM
the_merv's Avatar
Veteran: Air Force
The LT1 Radiator has more capacity.
Old Jan 8, 2009 | 07:46 PM
SOMbitch's Avatar
A 1" core instead of a 7/8" core. The LT iron block does not dissipate heat as well as LS aluminum and thus requires more radiator...
Old Jan 8, 2009 | 07:52 PM
demonpixel's Avatar
Cool. I'm swapping an LS1 into my 93 v6 Camaro body. Should I keep that v6 rad or should I get an LT1 rad?
OP, sorry about the hijack
Old Jan 8, 2009 | 08:54 PM
9000th01ss's Avatar
It'll fit in the body, but won't work with an LT1, the LT1 has a small hose fitting on the bottom of the drivers side tank, the LS1 radiators don't have this fitting. LT1 hose diagram.
Old Jan 8, 2009 | 08:57 PM
9000th01ss's Avatar
Now looking at post #9 I don't know why you asked.
So then yes and LS1 radiator will work in a '93-'97 f-body that has an LS1 in it.
