rev matching?
By rev matching, you are eliminating the wear and tear on the clutch that results from it having to match 2 different speeds, being that of the input shaft on the trans and the speed of the engine.
The proper (racing derived) way to downshift is to "heel and toe", which involves using your left foot on the clutch (as always), and using the heel of your right foot to press the brake and slow down as you use the tip of your right foot to blip the gas pedal to the proper RPM for the next gear you are selecting.
When I'm just cruising around though I'll blip the throttle on downshifts to rev match without touching the brakes, and just use the engine to slow me down until I'm near my stopping point, at which point I'll apply the brakes and disengage the clutch.
It takes a while to get a feel for the amount of throttle you have to give it between gears and at different RPM's, but once you start practicing you can usually just blip it and be within a couple hundred RPM of your target for the next gear.
So from a 55 mph cruise in 5th gear rpm ~1400 downshift to 2nd gear and while the clutch is in bring the engine no load rpms up to ~3700 and let the clutch out while mashing the loud pedal.
Double clutching is the only technique that benefits the synchros, which involves releasing the clutch, pulling the shifter into neutral, selecting the proper RPM with the throttle, putting the clutch in again, and then engaging the next gear.
Double clutch coming up to a turn, slightly tap the brakes and at the apex let her rip, assuming you have enough room and can control your car and not hit a curb
That last part wasnt coming from personal experience, i swear.
