Transmission ?
Old Jan 29, 2009 | 01:33 PM
eduardo's Avatar
Default Transmission ?
I have a 98 ls1 camaro and would like to know if any 4L60e will fit my camaro without having any problems. For example a tranny coming from an lt1 or even a truck or 6cylinder engine. If so does anything need to be changed?
Old Jan 29, 2009 | 03:42 PM
9000th01ss's Avatar
Only an LS1 trans will bolt to an LS1.
You can adapt an older 4L60E the same way th350, th400, etc are adapted. Or with a non LS1 4L60E you could change to an LS1 bellhousing, pump, and input drum. At least.
Old Jan 29, 2009 | 05:31 PM
the_merv's Avatar
That and with the older 4L60E's the electronics internally are different.
