emissions question
And it will not cause a backfire to my knowledge. It basically only runs at startup to help with emissions until the car is warm.
Why do you think it causes a backfire?
Go with O2 Sims. They can detect the thrown codes but the Sims pass (with the exception of visuals).
I was with a buddy when he failed for deleting codes. If their computer (OBDII) can't find the appropriate code you autmatically fail.
Also, may sound dumb but don't drive in there with you Check Engine Soon light on... auto-fail... i've heard from numerous guys (with mostly imports) explaing how they didn't see that onecoming...
Re'
It will pass with reporting turned off.
Information about this is best to be had in the PCM Diagnostics & Tuning section.
Also, a Readiness Test is not code reporting. You cannot tune out readiness tests. But, there are ways to trick the PCM into passing them.
