ls6 intake
ls6 intake
hey im about to buy a ls6 intake off of a member here and i was wondering if it is jus a direct bolt on? or am i going to need to buy anything else to make it work/fit? thanks
Unless you're getting an LS6 intake with an EGR port, you'll need a block-off plate for where the EGR connects to the manifolds.
Also, get some ratcheting wrenches. They'll help out _a lot_.
And, read up on the oil pressure sending unit and how you can avoid breaking it when doing the swap. It's very common to break it during an intake manifold swap, so beware.
^^^What he said about the egr and watch the brake booster hose doesn't brake the oil pressure sendind unit. You'll also need these http://www.texas-speed.com/shop/cate...MID=1&catid=12 the ls1 has a coolant pipe running under the intake. This is block off's for the rear head ports and a crossover for the front.
Sorry, but I don't have a picture of the underside of the intake after grinding, but I am confident you can figure it out.
