oil and filter question
What type of oil [ full synthetic, syn blend or reg oil] should I run in my formula and what brand filter[ I've always been a delco man] would anyone suggest?I just bought this thing and I want to do the right thing.
5w-30 mobile1 synthetic and mobile 1 filter here. LS1s r supposed to have full synthetic. avoid K&N oil filters. all you are buying is a crappy filter with a popular name. If you read the box, they only have a 90% filtering rate, while a mobile1 or WIX has 99.9%.
I run 0w-30 German Castrol full syn. and a AC Delco filter. You are going to get so many different post here. To bad the search isn't working becuase there is about 700 billion give or take, threads exactly like this.
1 Post
Any name brand oil in a 5w-30, changed at 3-5k mile intervals.
Any oil filter in the WIX family, M1, K&N, Purolator, Motorcraft, Delco, or Wal-Mart. The truck versions of the filter are a little taller and provide more filter area. I always buy two filters if I'm buying that brand for the first time and cut one of them open to see how they are made. Fram have cardboard endcaps to the filter media, the others have steel endcaps.
Good luck, and happy motoring.
Here is what I use for oil:
![](http://www.myoilstore.com/images/GC0W30.jpg)
That is the "German Castrol" that you may have heard about. It is what a lot of people use... must be 0w-30 and say european formula on it.
For a filter I use the Mobil 1 filter part# M1-206. It is a longer filter then stock, but fits well. I use this instead of the recommended mobil filter cause I like to go 6k on my oil.
Since you are gonna get a million + posts in the next few days with every Tom, Dick, and Harry saying what they run instead of answering your question I'll do the honors. Use a motor oil that is full synthetic. Mobile 1, Castrol, Quaker, blah blah blah. Make up your own mind with the brand by reading the back of the bottles. As for a filter, do the same thing. Just read the label and compare filtering ratings. You'll see the ones that have the better filter rating, (in the high 90%'s). I've heard some guys on here say they like the K&N because it has a bolt on the bottom so you can take it off with a wrench so it makes it easier. If there are multiple filters you can't decide on cause they both seem good or what not, read the labels and pick what you think will be best. There's a thousand people out there that will tell you that Mobile 1, K&N, Delco, or whatever is not good because their Mom's, sister's, uncle's dad heard they are crap.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
At the moment I'm using the one in the picture up there. 0w-30 European Formula. My valvetrain/piston slap seemed to get louder on cold starts, but it goes away fairly quick and overall the car seems to like it. Not really much of a difference than the last oil though.
Also, got the K&N filter because of the special AZ was having, lol.
since we are on the subject of oil. i have heard that cars with a good amount of miles on them should not use synthetic. and i was just curious if i could/should use this in my car. its got 118xxx on the clock.
