PORTED 75mm OR 80MM THROTTLE BODY
HEY, LOOKING FOR SOME OPINIONS FROM THOSE OF YOU WHO KNOW BETTER, SHOULD I GO WITH THE PORTED 75mm OR NEW 80mm FOR A STOCK LS1 WITH THE LS6 MANIFOLD. I'M PRETTY SURE THE 80mm IS THE MAX FOR MY SETUP AND I'M NOT GOING TO BE DOING ANY OTHER MOD IN THE NEAR FURTURE OTHER THAN LONG TUBES. WADDYA GUYS THINK?
i wanted to keep my stocker stock so i added a summit 80mm. for the $ port your stocker. the 2 issues with the 80mm TB was adjusting the cable, easy once i figured out how from ls1 tech and also i couldnt use an aftermarket bellows. the spacer for TB loses an inch or so distance between air lid and TB. CHEERS!
