Question on Ls2 motor and trans from vette
Hi,
Are 07 vette transmissions mounted in the rear of the car?
I talked to a guy over the phone that wrecked his 07 vette with ls2 and 6 speed in it. He is sending me pics tonight, but he said I can't use the transmission cause it is was bolted in the back of the car. He said that you can only use the trans if your are putting it into a vette again. I have no clue what he is talking about, maybe he doesn't either. Just figured I would double check with you guys. Maybe he is confusing the trans with something else. Sorry for the dumb question.. haha
i believe some ls2s that came in goats have a 54 tooth reluctor wheel but you need a 24 bit, they make conversion kits but idk about ls2 vette motors. im not 100% sure so if someone with more experience can chime in it would prob help more. But besides the harness and conversion kit i think thats it, should bolt right up. Are you keeping it a 6.0 or gonna make it a 408?
option. you will also have knock sensors on sides of block instead of iin the valley cover, and a front cam sensor. you will have to make provisions for all of this into your harness. you can pick up the coversion kit from lingenfelter, or i think mast motorsports...maybe wrong. good luck.
