Does LS1 bolt to 700r4 transmission
Hi I own a 1954 Chevy pickup currently running a 350/350 combo but was wantin to drop an Ls1 into it...i am currently not satisfied with the turbo 350 transmission in it and was thinking of putting a 700r4 in...but from my understanding it wouldnt bolt to the LS1...is this true...can anyone help with transmission suggestions for an LS1 i am looking for an automatic preferably 4 spd.
I'm running a 700 behind a 5.3. I used a spacer between the crank and flex plate. It's available from SDPC. I recently read that one of the aftermarket trans companies (maybe TCI) has a flex plate that doesn't need the spacer.
The bell housing bolt pattern is not an issue and those old wives tales about 700 transmissions blowing up are no longer valid. They can be made plenty strong. The only thing that one has to be really careful about is the TV cable adjustment and Bowler Transmissions has a kit to take care of that. Good luck with your project - you will like the results.
