Engine temperature question
I have converted a 2004 LM7 engine into a Factory Five Roadster ('65 Cobra replica) and have a question about the t-stat AND programming. I have read a lot of posts and they differ from 160 degrees to 195 degrees. I realize that whatever t-stat I run I should have the programmer set as the Fan On mark also but what is the optimal temperature setting? I'm under the impression that an EFI needs to run warmer to operate at it's peak performance...
My only mods have been a pretty aggressive cam/springs, LS6 intake/TB and custom long tubes (clearance issues with anything stock) if this makes any difference.
Thanks,
Chris
Thank you for the response as I've seen what you're speaking of and possibly I'm confused. You have a 160 t-stat but a different fan on temperature mark. Is this common as I thought they should be set at the same mark?
Chris
Sounds like a cool project.
Full head on shot
Right side headers now done, waiting on SpinTech mufflers to arrive.
Typical build runs side pipes. I'm going with a full stainless under car exhaust which given a 4.5" clearance needs to be custom.
Chris
