Stall ???
Old Oct 25, 2009 | 03:36 AM
camaroboy14's Avatar
Default Stall ???
I am going to be getting a stall converter and wanted to know what one to get rpm wise? 2500, 3000,3500, i wanted to know also how it works..cuz i am not sure if some one can explain it..please..off the line how does it work? And when i am driving does it affect anything?? My car is a a4 lid,gmmg exhaust, preetty stock.but when i get the stall i will have a cam kit not sure which yet and also lt s wit a ory..mayb shift kit too...
Old Oct 25, 2009 | 09:54 AM
SOMbitch's Avatar
Your stall needs to match your cam but even my 3600 was good before the cam went in. Do some reading in here and search it in the tranny section.
http://www.converter.cc/tech_talk/
Old Oct 26, 2009 | 06:43 AM
BlackScreaminMachine's Avatar
Internet Mechanic
One word of advice, decide what cam will go in there and we can recommend a stall that is appropriate for you. Also if you have 2.73's start planning on a gear upgrade too.
The average LS1 A4 Owner does no less then 3500.
As for the stall and what it does, it allows the transmission to slip and depending on the throttle input and at what given mph your at, it will act differently.
Driving a stalled and stock stalled car, there is a difference but to me its not an issue. It's part of the game.
Old Oct 26, 2009 | 11:18 AM
TXZ28LS1's Avatar
my car is a daily driver and i have a 230 size cam with a vigilante 3200 stall. it is very perfect for a daily driver. but honestly, after driving this stall for a bit now, i could easily step up to atleast a 3600 stall.
Old Oct 26, 2009 | 12:51 PM
2002t/a06's Avatar
I would get at least a 3500 as mentioned above. It will really wake up the car. Do you have any idea what cam you might go with?
Old Oct 26, 2009 | 11:15 PM
Default cam i might get
thnder racing 224 224 112 99tr on the web site its the seventh down on the thunder racing website...
Old Oct 26, 2009 | 11:47 PM
slayerized6's Avatar
3600 and 3800 stalls are popular options. howver, it all depends on if you plan to upgrade your cam and rear end gears
Old Oct 27, 2009 | 12:17 AM
Detoxx03's Avatar
I went with a Yank SS3600. Took me a couple days to get used to so now I don't even notice it. I wouldn't buy another if I could
Old Oct 27, 2009 | 06:23 AM
MonmouthCtyLS7's Avatar
3600 here and love it..
Old Oct 27, 2009 | 07:44 PM
second_2_none's Avatar
I had a 4400 stall and it was a bit to much for the street and there was no way I could spray on it. So I sent it back in and got a 3600 nitrous converter. Its a lot tighter than my buddies 3600 just because mine is ment for nitrous but I am still able to pull 1.6x's with mine. With a 224 cam you can go with a smaller stall, but I would deff go with a 3600. Most people that get smaller stalls want to get bigger ones later on. Good luck with it though, you will love it and its the best upgrade you can do to an auto!
Old Oct 27, 2009 | 11:26 PM
Charlay's Avatar
Im looking into a stall too, there is a ton of info on here about them. Make sure you match it with the right cam. There are videos too on here that run you in the car to see what the RPMs look like and so on also. Good luck man
