Autometer c2 gauge ?
Ok I have a set of autometer c2 electric oil pressure and water temp gauges coming in(2 1/16), did some looking and I wana be sure on this, for the oil temp I plan on drill/tapping the plug above the oil filter this will work correct? And the second is for the water temp can I just remove the factory sender and replace it(if so what adapter do I need) or pull the starter and replace a freeze plug.(what adapter here also) with the factory location will I need to tune the PCM since it won't be going thru the PCM and cause a cold start fueling issue at all times?(both my oil and temp gauges are dead so I don't care about keeping them same tuning ? With the oil also) answers the sooner the better ofcourse while my comp is with frost.
