ported heads???
Old Nov 11, 2009 | 03:02 PM
camaroboy14's Avatar
Default ported heads???
How much does it cost to port heads? Also how much power is gained by doing this? If u get them ported by the right shop? Does n e one know who will be a great place to send or take them too...I mean a good place.....also I was wondering if I should just get a h/c paCkage by trickflow....but right now just trying to find the best and smartest way to get it done thanks guys
Old Nov 11, 2009 | 03:32 PM
Jon@Texas-Speed's Avatar
What heads do you have? We offer CNC porting as well as upgrades to larger valves and better springs. We can also get you setup on a complete cam package. Give me some details on your car and what you have done as well as some goals and we can get you fixed up with everything you need!
Jon
Old Nov 11, 2009 | 05:14 PM
Thumbs up contact me ...
yeah my car is pretty stock the heads aswell are stock.. the car is a 2002 ss wit the 345 hp pac right now not much done by dec should have lts qtp and cut outs.. but the car i want to of coarse either port the heads and get a cam the rear end was going to swap out aswell also deciding on what i am going to do about the trans..build it or swap it out also..3600 stall and fast intake/90mm tb and some other stuff is in the picture aswell but the building will start jan. and i am very serious...just need some help getting it done...my email is camaroboy14@hotmail.com so please contact me...wit any info...
Old Nov 12, 2009 | 02:13 PM
What are you wanting out of the car? What kind of driveability are you wanting? Would you like me to quote you on a cam package and porting your heads? Let me know and I'll make it happen!
Thanks!
Jon
Old Nov 13, 2009 | 12:47 AM
Default please give a quote..
looking for it to be a DD still, but make about 420 hp to the wheels will be happy wit that..thank u 4 being so helpful...also looking for something that sounds awsome and thanks 4 ur help jon also in the pac let me know exactly what i will be getting ....thanks
Old Nov 13, 2009 | 10:59 AM
First thing I would get is a set of LT headers and a stall converter. Really any aftermarket cam needs some LT headers to get the full potential out of the cam. A set of Pacesetter headers would work fine. It doesn't take an expensive stainless set. Also, a converter will open your options up for camshafts. With the stock converter, you are really limited to something like a 224 duration camshaft. Any larger than that, you will more than likely be pushing through the brakes.
Realistically, to put down that kind of number, it is going to take a camshaft in the 230's on the duration with a good set of heads. Keeping it budget friendly, I would probably look at the PRC 2.5 5.3L heads and cam package. The heads will come fully assembled w/ stainless valves and PRC Dual .650" springkit. These will be ready to go out of the box. They will also give you a decent jump in compression with the 62cc chambers. Depending on cam selection, you can probably mill the heads a bit more to bump the compression further.
From the sound of what you are wanting out of the car, I would go with something like a Torquer v.3 cam and these heads. The cam will have a nice aggressive idle yet still drive well on the street. I would put in a 3000 stall speed converter and you should be set. It would make for a pretty quick street/strip car. Let me know what you think and we'll see if we can get some pricing put together for you!
Thanks!
Jon
Old Nov 14, 2009 | 08:59 AM
qwik219d9's Avatar
Default porting 853 w/ stock size valves
Jon
how much $ would I have to give to have my 853 w/ stock size valves, ported?
what all is done? deshould valves?
5 axis port?
mill?
flow test?ect.
how long doe's it take & will I get the same 50RWHP that you'all claim on the PRC heads?
Lastly is PRC affilleated Texas speed because looks like you are the only co. that sells PRC?
Old Nov 14, 2009 | 10:41 AM
SOMbitch's Avatar
Thanks!
Jon
C'mon Jon!!! Not trying to be a nit picky douche but you, me and others on here know that after your bowl cleanup those heads are are 63cc and a little change. An OEM 5.3 head is 62cc but you already know this.... I cc'ed 2 chambers on each of my PRC 5.3 heads and they were all slightly more than 63cc. Others on here have had the same results so it is not just me!
I know it is still good for about .6-.7 point pickup in compression but why don't you just be upfront about the actual chamber size?????
Old Nov 14, 2009 | 11:06 AM
cool whip's Avatar
Originally Posted by camaroboy14
Does n e one know
I have now idea the answers to your questions. But do you realize typing "n e one" takes up 7 spaces and "anyone" takes up only 6?
