intake manifold
is there any way to tell the difference between an ls1 and ls6 intake manifold wen they are installed? ive been lookin into this but can only tell the difference if the 2 are not installed
A really quick way is checking for EGR. If the hose is coming up right behind the throttle body then you have EGR equipped, and it's MOST LIKELY a ls1 manifold. However, it could be a SLP ls6 manifold that has EGR on it, or someone could have removed EGR from an ls1 manifold.
Check here for part numbers to be sure.
I know the OP found his info but maybe this will help somebody out.....http://www.c5help.com/partnumbers.htm
