Rear end replacement help.
Old Feb 18, 2010 | 10:00 AM
WizardofDetailing's Avatar
Default Rear end replacement help.
I have a 2000 TA 6speed, no traction control, but I do have abs. So I need to replace my rearend and was wondering if one with traction control will work in my car. What are the differences between 3 channel and 4 channel? What else do I need to know???
Old Feb 18, 2010 | 10:03 AM
bww3588's Avatar
i have a complete 3ch rearend with 4.10 gears in it if your intrested. im in Lima, Ohio. somewhat close.
Old Feb 18, 2010 | 10:07 AM
pm sent
Old Feb 18, 2010 | 10:30 AM
406malibu's Avatar
LOL did you break the rear end that you swore you couldn't break?
Old Feb 18, 2010 | 10:42 AM
LMAO @ U
No I didn't break it. I bought the car a few months ago and it was humming when I bought it. I can't stand noises like that so I'm swapping it out and with another 10 bolt w/ 4.10 gears. Yes I know you are going to tell me I'm going to break it, but whatever I DON"T CARE ABOUT YOUR OPINION ON REAR ENDS, I simply need some knowledge on what the differences are on the 3 & 4 channels, will a 4 channel work in my car, and what I should know before hand. DO YOU have any helpful info to give or are you just here to talk ****??
Old Feb 22, 2010 | 11:08 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
https://ls1tech.com/forums/gears-axl...r-end-faq.html
https://ls1tech.com/forums/gears-axl...-3-w-pics.html
mechanically,you can use a 4ch rearend assy. in a 3ch vehicle but ABS will no longer function.
Old Feb 22, 2010 | 11:32 AM
98z-28redcamaro's Avatar
4 channel the exciter rings are on the ends of the axels next to the wheel studs. 3 channel the exciter ring is between the carrier and ring gear
Old Feb 22, 2010 | 11:27 PM
PowerShift408's Avatar
Off topic, but how in the hell did you manage to get your car to make more torque than horsepower N/A?
