header install
Old Dec 29, 2003 | 07:44 PM
mweldy's Avatar
Default header install
This question is not really about headers. The instructions said I need to raise the car 36 inches. Do you think cement blocks instead of jack stands will be a safe solution.
Old Dec 29, 2003 | 07:55 PM
Ryan04Silverado's Avatar
Get the jack stands. To get it that high, you may want to look for the truck jack stands which allow you to get it to that height. Safety first!! Good luck.
Old Dec 29, 2003 | 09:12 PM
SMOKIN01TA's Avatar
most cement blocks will crumble (on your head) dont use them.
i used a floor jack and a chunk of a 6x6 underneath the plate on the k-member
Old Dec 29, 2003 | 09:15 PM
SMOKIN01TA's Avatar
oh yea and the back was on ramps.
Old Dec 31, 2003 | 10:01 AM
4mula1's Avatar
Never use cinder/cement blocks, you might get away with it for awhile, but the car only needs to fall on you once! Smokin01's method sounds like the way to go.
Old Dec 31, 2003 | 10:07 AM
onebadz's Avatar
Just get a good set of truck jack stands, you will probally use them other than this time. Do the safe thing man...you wouldnt want to hurt you or your car. Good Luck
Wes
Old Dec 31, 2003 | 10:10 AM
z289899's Avatar
Stands are the only real safe way to go.
Old Dec 31, 2003 | 11:13 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
I used a floor jack and a block of wood too. Not the safest of methods, but that's what I did. I also had a friend there to help me out. Here's a pictoral look at my header install....
http://www.geocities.com/y2k_ta/smr0...erinstall.html
Old Jan 2, 2004 | 05:40 PM
BlackWS602's Avatar
Jackstands are below 10$ a pair. Don't be cheap with your life
Old Jan 3, 2004 | 03:12 AM
Blacker's Avatar
I used 4 jackstands and had the car raised 19". No problems getting those headers in.
Old Jan 3, 2004 | 03:47 AM
NVDZ28's Avatar
Yeah i have a lift in my garage and it makes it a whole lot easier.....It made putting headers on like it was nothing.....
