quick question on the GTO LS1
Originally Posted by jdp244
the gto doesnt have a different cam in it...
the gto will not have true dual exhaust due to the gas tank relocation.
http://www.pontiac.com/gto/index.jsp?source=hmlnav
Who says we don't have a hi-lift cam with a flat torque curve?
In my defense, I don't understand any of those lift/duration/degree jargon for engine internals, though i'm trying to learn!
Just a little info,
The '04 GTO(V-body) uses camshaft part #12561721 same as 01-04 Y-body (Corvette),01-02 F-body, 01-04 K-truck (6.0 4x4), and, 03-04 N-truck (H2)
cylinder heads are the same as 99-current f and y cars.
It does have true dual exhaust with an h-pipe.
Ron
Ron
Originally Posted by Kurt D
So, why does Pontiac's website say it has a high lift cam for greater peak preformance and flat torque curve; and "...the GTO exhaust system is true dual..." AND shows a picture of the setup?
I think people get confused because the pipes are routed out the same side.
It is in an MS Word Document.
Hope this helps.
In certain respects, the GTO LS1 is similar to the variant previously used in the Chevrolet Camaro and Pontiac Firebird, as well as the version GM Powertrain builds at its St. Catherines, Ontario assembly plant for installation in the Holden Monaro in Australia. The primary difference between these LS1s and the GTO variant is the camshaft, which is taken straight from the Corvette LS1 for improved engine performance. With the Corvette cam and other powertrain modifications, the GTO LS1 delivers off-the-line launch characteristics appropriate to a muscular coupe of the GTO’s heritage.
http://www.gmgoodwrench.com/gmgoodwr...283§ion=ep
12480033 Camshaft "Gen 3" (Hot Cam)
The "Gen 3" (RPO-LS6) engine is used in all 1997 and later Corvettes, and 1998 and later Camaro/Firebird vehicles. This camshaft is comparable to the LT4 hot camshaft but for your LS1 engine. This kit includes 16 LS6 valve springs P/N 12565117.
12480110 Camshaft, "Gen 3" V8 (LS1)
The "Gen 3" V8 (RPO-LS1) engine is used in all 1997 and later Corvettes, and 1998 and later Camaros. This camshaft is designed for ASA racing and has .525" lift on 110º center line. Use with "Gen 3" LS1 engines only.
12565308 Camshaft, 2002-03 LS6 Corvette
This is the production cam for the 2002 LS6 Corvette. It features .550" intake and exhaust lift, 218 degree exhaust duration, and 204 degree intake duration at .050", and 117.5 degree lobe centers.
12560950 LS6 "Gen 3" Production Performance Camshaft
This camshaft is original equipment in LS6 Vortec engines. It features .525" intake and exhaust lift, 217 degree exhaust duration at .050", 207 degree intake duration at .050", and 116 degree lobe centers.
These are the 4 part number options from the GM performance parts website for camshafts (from link above - there is also a 'showroom stock' replacement part). That being said - I've looked everywhere for a part number of the GTO and can't find it. All is says is that it is 'revised' from the cam in the Holden spec LS1.
Dan
Dan
Notice how the Goodwrench site says:
"12480033 Camshaft "Gen 3" (Hot Cam)
The "Gen 3" (RPO-LS6) engine is used in all 1997 and later Corvettes, and 1998 and later Camaro/Firebird vehicles."
and then says:
"12480110 Camshaft, "Gen 3" V8 (LS1)
The "Gen 3" V8 (RPO-LS1) engine is used in all 1997 and later Corvettes, and 1998 and later Camaros."
So, they are saying you could get a LS6 since 97 in the Vette, and 98 in the F-bod.
and then says:
Originally Posted by jerflash
if look at the pontiac site it says it also has a 100MM TB and intake
is that true about the h-pipe?
Yes it is true there is no exhaust crossover - completely dual from manifolds back.
#33
Well, the initial plan is to keep her stock for a bit. The first thing I'll do when that 'bit' is up (I'm building a SBC for the summer to keep my tinkering focused) will be to do headers and exhaust back. At this point my only question is should I go for high-flow cats or dish them altogether. I should get some good (and bad) results from other people modding the exhaust to help me pick the right setup.
#35
Don't you guys forget that the Aussie LS1 come with a LS6 intake, i think that they would have changed the tune slightly as well which is what they do to our cars each year when a new model arrives. The LS1's started with 220kw standard in Aust now come as 245kw standard.
#39
#40
It does not connect. I have heard arguments that you can actually get more HP from a crossover exhaust due to 'pulses' helping to extract gas from the combustion chamber. As I'm not concerned about absolute optimum performance, I will probably keep it as a true dual setup. I'm partially waiting until next spring to get a good idea of what systems are better than others w/ the GTO setup. At that point I'll decide for sure. It definitely needs headers. I hate the look of manifolds in such an otherwise beautiful engine compartment.
Dan
Dan
