what to expect
?? No dtc's ?? You may have a problem if thats the best you ran or your DA is 10,000 . Maybe clogged cat converter,fuel filter or bad fuel pump ?? If you think it feels strong now, just wait till you fix whatever is causing the ~100hp loss.
Wow, that's extremely good MPG for an A4 that's running poorly enough to be down about 100 horsepower based on your trap speeds. Is that 100% highway driving for 28mpg?
They do. ET isn't as important of a factor because traction can vary so much from car to car, but trap speed for any stock LS1 should always be above 100mph. The normal range for a stock LS1 (depending on trans type, weather, elevation, etc.) is about 103 to 108, with most cars falling somewhere in the middle of that.
Even if you're racing in Denver, those numbers are extremely low for even a stock LS1.
Anyway I'm Subscribed, this could turn out to be funny and bad at the same time if hes got a 6er instead of a V8, lol. I hope you don't guy cause that would SUCK.
