Question about 98' camaro LS1 engine
I have a 1998 camero ls1, i was told by this performance shop that is i put a after market cam in it that the engine will blow something with the crack or something another. Is this true, because i have suffered the internet and can't find anything on that happening. Thanks for the help!
So are you saying your block or heads has a crack?
If not and your engine is good condition then you don't have any worries as long as you don't go too big of a cam with out fly cutting you pistons. I k ow many guys with 98 engines with decent sized cams.
The engine is in good condition, i bought it off a guy and i am putting it in my 1993 325i bmw, and a buddy who has a ls1 and works says is in good condition. I just didn't know if this guy was telling me the truth, i am buying my wire harness from him so that why he told me to be careful with cam that engine. Thank you for the reply.
LS1Tech Administrator
Received 1,727 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Nah, '98 PCM is no problem for a basic heads/cam setup and a decent tuner. It's harder with an aggressive forced induction tune though.
I just do not know what this guy is talking about the cam breaking the crank shaft, but he got me worried because i went to his shop and saw the crank shaft, it was just scuffed up, so i have no idea. I am new to this ls1 stuff, first time with a v8 period. Thank you guys for the help and advise, i will get you the spec on the cam when i buddy give me the link.
The only way that an aftermarket cam will cause engine failure is if you don't install the proper valvetrain components to handle the cam, and/or you don't have proper piston-to-valve clearance.
There are thousands of people on this very site with '98-'02 LS1s that have aftermarket cams, many also have aftermarket/reworked stock heads, and various power adders including N2O and turbos/blowers; also stroker motors. These are very strong engines, so long as you use the correct parts when setting up the package you won't damage a *healthy* engine (all bets are off if the motor was in poor shape before the mods).
Numbers in sig with stock 98 bottom end and drive it several times a week. You need to find somebody who knows LSx motors to help you. Coming from the Gen I world I had a lot to learn and unlearn......... But I LOVE these things...They make power so easy...
I am saving for a LS2 402 and fully expect to have a mild mannered 500rwhp+ car....
