crankshaft?
You need a machine shop to check it for excessive wear on the rod or main journals. Chances are if it needs anything you can turn it .010" and run a +.010 bearing and you will be fine. The stock cranks will take a good amount of abuse so chances are you won't need an aftermarket crank. However, if you want to put one in, we can definitely get you fixed up with anything you need for your build.
Jon
Jon
