Weird Idle
you depend on closed loop to bring it around. This has a lag
to it. I would check that the manifold install didn't leave you
with a vacuum leak, first. You need to be able to see the
LTFTs and O2s.
A change in behavior that (maybe) is event-related might
have to do with something coming loose, O2 wire getting
burnt, etc. Have to do some inspecting over & under for
that kind of thing.
People will want to know what kind of stuff has been done
to the car in the way of bolt-ons that might affect mixture.
The signature is a good place to lay the cards on the table.
You DID use rear O2 simms didn't you???
did you do the idle relearn procedure :dunno:
Idle is done automatically after a few drive cycles if it is not done immediately after replacing power to PCM.
Keep us informed.
. its a good idea to install a new timing chain on a 98-00 car during a cam swap. i bought it for 75 bucks from TSP, and its adj. cant beat the price. and great insurance against breakage. you dont want a broken timing chain
