99 camaro ss feeling slow
This is often the result of K&N-type filter use. People over-oil them, and this is what happens over time. I'd rather just stick with paper for any applications that use an MAF. And if you absolutely insist on getting that 0.5 hp gain from the K&N, then make sure to check/clean the MAF on a somewhat regular basis (at least with every plug change).
Oil additives are crap for the most part. Steer clear IMO. The only possibile exception would be something like ZDDP for the old flat tappet cammed engines, since most modern oils seem to be reducing zinc content. Even still, I'd rather just stick to a specialty oil like VR-1 that has the proper base structure for old engine applications.
LS1Tech Administrator
Received 1,692 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
if this is true i will start doing it on every fill up, anyone else heard of this?!
Raising octane without a need for it will only cause a decrease in performance and MPG. If you aren't getting detonation (and don't see KR on a scanner), and aren't boosted/spraying, then stay away from anything more than premium.
I Guess That's Just How I Type... Not Sure Why I Do It... xD
edit- mileage is not as good, 2-3 mpg less
update...
went to etown tonight and ran a best of 13.8 at 104. so just cleaning that sensor netted me 1.3 sec and 8 mph. The banging was really bad launching cause the drag strip was pretty well prepped. So i'm sure i'm still hurting from that, other wise i'd say the car is in alright shape. Still need to get the y pipe fixed, the shop said they would do it next thursday.
Definitely a huge step in the right direction! ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Your trap speeds are still a little slow for a LT header/ORY M6 car. Should be more like ~108ish. I would not worry about that until you fix the Y-pipe though, as KR could certainly be causing a reduction in power. Might also benefit from a custom tune for the exhaust to get the most out of it.
#32
