Window Tints
Old Jan 19, 2004 | 12:23 PM
do0dfromcali's Avatar
Default Window Tints
Anybody know of a website on how to do window tints?
Thanks,
Mike
Old Jan 19, 2004 | 04:03 PM
Orange99Z's Avatar
Don't know of any websites, but it's not hard. This is easiest with the window out of the car and a warm place to do it.
I do it this way:
1. cut the tint close to the right size
2. clean the window
3. soak the window with water or something (I use Windex)
4. pull off the backing and put the tint on the window
5. squeege (< sp?) the air bubbles out
6. trim with a razor blade or sharp knife
7. let it dry for a day or two before you put your window down
There are probably better ways but this works for me.
Old Jan 19, 2004 | 04:40 PM
x phantom x's Avatar
STF veteran / 10 second club
What he said ... I would just like to add one or two things.
1) When you precut the Tint, do it so it is about 1-2 inches too large on all sides ...
2) When you squeege (no clue on sp), start from the middle and work your way out, making sure to get rid of all the bubbles in the middle .... you can also start from one of the sides and work your way to the other side ... whichever you choose.
3) After you get all the bubbles out, retrim it the best you can, leaving a small space of just window on each side ... maybe | | about that much, so the tint wont get caught on **** and the edges wont start peeling off. I have had mine on for alil over 2 years now, with no bubbles or anything.
4) Take the side windows out and do them as he said .... THEN attempt to tint the rear, since it is a bit trickier. Also when you tint the rear put a sheet over everything so the water and whatnot doesnt go all over the place, start from the top and work your way down.
5) Pick a good tint.... too dark sometimes looks dumb, unless you have a black car, too light also defeats the purpose. I have 5% on my car and it blends in nicely with the black paint, but I would probably go 10% or greater on a car that wasn't black.
6) Do the same tint on the windows as you are going to do on the back ... my first time tinting my old car, I used 20% ( I think ) on the sides, and 10% on the back ... it looked stupid since they were different.
That should be about everything ... just take your time, and if you mess up just redo it, no biggie.
Old Jan 19, 2004 | 04:47 PM
KALEL's Avatar
put the tint on the OUTSIDE of the window and cut it...since the window curves and the tint was on the outside of it, it was cut slightly bigger..this is how mine was done and it is perfect...just my .02
Old Jan 19, 2004 | 04:49 PM
Uhhh, the tint goes on the INSIDE of the window tho?
I think I misunderstood your post ...
Old Jan 19, 2004 | 04:52 PM
KALEL's Avatar
yea i know...i thought the same thing when i saw this being done...if u put it on the outside,cut it, then put it on the inside it will fit the way its supposed to...just a lil trick i learned
Old Jan 19, 2004 | 04:53 PM
Ah cool, I've never tried it that way ... sounds like a nice trick tho.
Old Jan 19, 2004 | 05:06 PM
Deech's Avatar
PR Director
Yes this is true. The guy who did my tint did that to mine and it came out perfect.
Old Jan 19, 2004 | 05:23 PM
demonspeed's Avatar
It's not mine! woo hoo!
I hate when people call it "tints". It just bugs the **** out of me. Tint, Tinting, or Tinted.
Old Jan 19, 2004 | 07:06 PM
DeepBlueZ's Avatar
kind of like when wheels become "rims" right???
Old Jan 19, 2004 | 09:28 PM
pimpmaro's Avatar
Amen.
Old Jan 20, 2004 | 11:01 AM
Originally Posted by pimpmaro
Amen.
You should check out my tints, along with my new rims
I really apreciate the info on the window tinting
But now could someone explain the back hatch. Do you have to line up the tint in like 2 strips to get the whole back window?
Thanks
Old Jan 20, 2004 | 12:20 PM
demonspeed's Avatar
Mine is one big piece. I bought the car tinted, so I can't comment on how to do it.
Old Jan 20, 2004 | 01:16 PM
PendragonZ's Avatar
Chop-Foo Director
Have fun with the dot matrix
Old Jan 20, 2004 | 09:42 PM
KALEL's Avatar
do the back window the same way, putting the tint on the outside..as far as the dot matrix...it will bubble no matter what...it might not at first but it will so if i were you i would get a vinyl strip to cover that.
Old Jan 20, 2004 | 11:27 PM
BYOFICR's Avatar
I F***ed up a whole peice of tint trimming it on the outside. I had it backwards as if i was going to tint it from the outside so it was reversed
