Solid Motor Mounts or Poly
I am not a fan of the Spohn solids. Vibration wasn't bad but they raise the engine at least an inch.... Which gave me huge problems clearing my Vic. Jr.
When I replaced the K-member I swapped back to poly mounts. There are 8 second cars running around on poly mounts. Save yourself the trouble and don't use the solids.
The reason I have to change the Mounts is because my brother put the SS into a tree in a parking lot while drifting and tore the drivers side.The trans mounts are shot just due to normal wear...and I know, bad mistake letting my bro drive my car..could have been worse tho and he paid for the damage so I learn a lesson that day...Chalk it up, I learned.
From what I heard about the solid MM from Spohn directly - they set the motor at stock original height - not sure if I really believe the myth on the raising the motor 1". Why would they sell a product that did that...doesn't figure out.
Appreciate the feedback once again. Thanks for your time and info.
I owned a set and have worked on a few other cars with them. I hate to be blunt, but I don't care what they say about them (unless there has been a MAJOR redesign since I purchased mine). They raise the motor. It almost seems as if they forgot to figure in the deflection of the rubber/poly mounts when they designed the product.
I think the reason say the solids raise the motor is because the stock mounts sag/squish down as they get older. I'd imagine if you could take an engine height measurement on a car with brand-new stock mounts and solids, there'd be very little variance.
In order for the solid mounts to actually raise the engine, they would have to be designed at a different angle than stock mounts.
I agree that they would have to be designed differently to raise the motor, which is what I proport they do.
I replaced a set of solids with a BRAND NEW set of poly mounts (which would sag much than stock mounts even when new) and the motor set SIGNIFICANTLY lower.
I'm not trying to bash, just trying to save someone trouble.
Appreciate the lookin out brough... still haven't decided - if u r running 10's with the Poly's, and still like them, that says something. That's a fast a_ _ streetcar.Got to get the SLP 02 LS1 fixed before September... mom is coming back out to AZ and she wants to drive the ( her ) Vette.
What do u run brough ?? ES or Prothane
8.7 / quarter - thats fricken awesome. I want to keep mine a DD as of right now. Low to mid 11's would be fine...Looking at a couple of turbo's
#32
brough, u have been a big help-Thanks. I will def go with a poly trans mount, still unclear on the MM tho. Who is running the best trans mount right now ?? Spohn has a nice one that claims it will keep everything straight and true, then theres ES and Prothane.
Thanks to u as well shiv15... every little bit of info is helpful.
#36
Agreed... The only reason I would put solids on a car is if I had a mild turbo car with a kit like the PTK kit that burns up rubber/poly mounts. Otherwise I'd leave poly mounts until I had committed enough to putting motor plates in the car (which are soooooo sweet and make life much easier).
#37
Much appreciation on the feedback to all - Big Help.
Some say the Prothanes are too hard... ES are too soft... ( i know, this sounds like Goldilocks and the 3 Bears ) and yes, I have a hard time making decisions. I want these MM's to last - not too concerned with the trans mounts, even I am pretty sure I can tackle those.
Anyone have any knowledge of the Spohn Poly MM's ?? Thanks again for the input.
#39
It helps long tube headers to fit in easier, prevents y-pipes from banging on the floorboard, and transfers more power to the wheels.
