Rpm's rise a little with a/c on
It should raise the idle 100-200 rpms when you engage the a/c. The engine needs more power to run the compressor.
What is substantial to you? The way you put it, makes it seem like when you turn he a/c on, its going from 600-800rpm idle to 2500 rpm.
LS1Tech Premium Sponsor
Yes, that's perfectly normal!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
