installing LT's
Old Oct 4, 2010 | 06:53 PM
WS6SP33D's Avatar
Default installing LT's
How long does it usally take to install LT's? in a full garage with lifts and every tool possible. trying to figure out how much time i will have to free up, thanks guys
Old Oct 4, 2010 | 07:04 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I've done it in an hour with the car on jackstands. But I don't have AC or any of the other crap in the way
If you don't run into any problems I'd say 1-2 hours easy
Old Oct 4, 2010 | 07:05 PM
TheBlueKnight's Avatar
If it was still my first time if I started at 8am could probably be done by 2pm. If I did it again with the experience I have now, probably knock off an hour or two.
Damn, 1 hour? You'd be haulin *** to get all the old stuff out and put in all the new stuff.
Old Oct 4, 2010 | 08:19 PM
zracer323's Avatar
I would allow 6-8 hours if you have never done it before.
Old Oct 4, 2010 | 08:54 PM
Z28/2002's Avatar
It helps when you only have about 36" of exhaust on each side. Yank plug wires off, pull plugs and start unbolting the headers
Old Oct 4, 2010 | 09:14 PM
Carter Hays's Avatar
^^^This. Some fit better than others, so that makes a slight time difference.
Old Oct 4, 2010 | 09:27 PM
WS6SP33D's Avatar
i done alot of headers of mustangs but never one of these just wondering what to expect thanks again guys
Old Oct 4, 2010 | 09:28 PM
PadenAlbin's Avatar
Took me and a bud 18 hours. Installed LTs, motor mounts, tranny mount, new plugs and wires, and removed air junk.
When your doing it just don't take too much time and take plenty of breaks to ease the pain in troublesome parts of the install.
Old Oct 4, 2010 | 11:27 PM
flintwrench69's Avatar
Its about a 5 hr job but I would allow 6-8. Once you get the old manifolds off that is the time to replace or install some poly motor mounts if needed.
Old Oct 4, 2010 | 11:37 PM
smok'nZ's Avatar
MASS seller approved
if you have a lift/air tools no reason why it should take more than 2 hrs i did it in my driveway with a hand tools and a hand saw to cut the stock exaust and it took about 5 hrs
Old Oct 5, 2010 | 12:19 PM
thegodfather899's Avatar
i would say 5-8 hours. allow time for things to go wrong cuz you know they will...
Old Oct 5, 2010 | 12:28 PM
Mumbles's Avatar
If you can afford to be without the car, I recommend putting it up in the air, either on a lift or jackstands, a day or so prior and soaking all the bolts/nuts with penetrating lubricant.
This will help to speed up the disassembly process.
Old Oct 5, 2010 | 04:15 PM
WS6SP33D's Avatar
Is there a certain torque spec on the headers to heads?
Old Oct 5, 2010 | 04:53 PM
2000ssowner's Avatar
here's list of torque specs. hope this helps: http://www.ls1howto.com/index.php?category=1
Old Oct 5, 2010 | 05:29 PM
WS6SP33D's Avatar
hell yeah thanks
