cam position sensor
Old Oct 20, 2010 | 06:48 PM
jwf02ta's Avatar
Default cam position sensor
Here's the problem I had a code p0343 for the cam sensor so I replaced the sensor. And it still gives me the same code and the car is still hard to start it did not affect the performance at all. And I don't know if this has anything to do with it but the tach does not work and my abs and tcs lights are on. Has anyone had anything similar.
Old Oct 20, 2010 | 07:24 PM
Jays_SSZ28's Avatar
Where is the sensor that you replaced located?
Old Oct 20, 2010 | 07:49 PM
jwf02ta's Avatar
its behind the intake you have to pull the intake to get to it
Old Oct 21, 2010 | 08:25 AM
1lejohn's Avatar
You might check the harness for a bad connector or burnt wire. Thats the correct sensor that you changed. Did you clear the codes after changing the sensor? Check the harness that plugs into the PCM it may be loose.
Old Oct 21, 2010 | 11:08 AM
jwf02ta's Avatar
Yup I reset the codes and just that one came back up. Ill check the plug at pcm and the wire harness tonight and let yall know what happens. Thanks
Old Oct 21, 2010 | 01:25 PM
jwf02ta's Avatar
K I could not wait so I did it on lunch lol the wires are fine and the plug on pcm is plugged in and torqued to spec
Old Oct 21, 2010 | 09:15 PM
1lejohn's Avatar
Bad new sensor? How about any blown fuses? Was there any metal on the sensor when you pulled it out?( it's magnetic) Is the sensor bolted in correctly?
Old Oct 21, 2010 | 10:02 PM
jwf02ta's Avatar
it only bolts in one way so its kinda idiot proof im thinkin mabey a bad new sensor too the old one had no metal on it. is there a way to test the sensor or the wires going to it? do you think mabey a bad pcm? someone told me that the pcm may have to be reprogramed with the factory settings????
Old Oct 22, 2010 | 08:17 AM
1lejohn's Avatar
I don't know how to test them, maybe with an ohm meter. I asked about the metal because I had a lifter fail and the cam sensor picked up the metal shavings. I don't know why the PCM would need programming. Do a search and try to find the trouble shooting guide from the service manual for that code. With the elec. drawing for that circuit aleast you could check for voltage at the connector etc.
Old Oct 31, 2010 | 06:18 PM
PwrdbyLS1's Avatar
Any news with your cam sensor problem. I got the same code, I running my new Gen 3 LQ9 with a Gen 4 timing cover with front cam sensor. The engine start and run but It take a bit a long time to start when its cold.
Old Nov 1, 2010 | 03:15 PM
tito01ramair's Avatar
Ok well just to add my words is my fbody was hard to start also changed sensor an still had problem then changed my fuse relay to ignition fix problem
Old Nov 2, 2010 | 08:21 AM
PwrdbyLS1's Avatar
Mine works now, I just switch side of cam sensor wires.
Old Nov 3, 2010 | 01:34 PM
jwf02ta's Avatar
Tito01ramair: where is that fuse relay at.
Old Nov 3, 2010 | 01:56 PM
jwf02ta's Avatar
Did you tach stop working?
Old Nov 14, 2010 | 07:40 PM
jwf02ta's Avatar
update: i just installed another sensor. it seems to start up stronger but still no tach and the engine light is off now. any one know how to get the tach working after a cam position sensor change
Old Nov 14, 2010 | 07:56 PM
jwf02ta's Avatar
ok never mind it work all afternoon and i just went out to move it and it was hard to start and the engine light is on again. guess ill take it to the dealer tomorrow.
Old Nov 15, 2010 | 07:48 PM
blackbird74's Avatar
I read a post describing my exact problem in detail, some1 mentioned a crank position sensor relearn was needed after it had been chnged. I wonder if a cam position sensor relearn would be needed in your case...........
Old Nov 16, 2010 | 10:48 PM
joshp14's Avatar
Was there any damage on the old sensor like maybe the cam reluctor wheel was contacting it?
For your wiring, the red is 12V, Pink/black tracer is your low reference, and brown/white tracer is your cam signal wire. These wires all go straight to PCM...no connectors or fuses in between.
I would unplug sensor, key on engine off, put a test light between pins B & C (red and pink/black) and make sure it lights. Then ohm check your signal wire from cam sensor connector to PCM. It's connector 1 pin 73 at pcm.
Also, there is no cam sensor relearn procedure.
Old Nov 16, 2010 | 10:56 PM
mjcotroneo's Avatar
you might have to a crank relearn which needs to be done by a tech 2 at a dealer. they will have to enter the crank relearn mode and they will have to hold it at different rpms when tech 2 says to. i used to have this problems when i had fbodies come to the dealer. ignition can also keep the tach from working. is your security light coming on and staying on at times?
Old Nov 17, 2010 | 01:40 AM
jwf02ta's Avatar
i checked the pins on the conector(they were fun getting to with the intake on) they checked out fine. i took it to the dealer monday and i saw the guy attempt to do the crank sensor relearn he veved it a couple of times then quit from what i saw on the screen i dont think he did it right. ill take it back to have it done again hope i get someone who knows how to do it and see if that works
By Brett Foote | 2026-06-04 05:00:17
