help, engine acting weird
also last night it was running fine but was making almost a knocking noise kinda like spark knock, shut it off started up and has never done it again, oil pressure was fine and it felt fine just heard a noise. what do you guys think it is? fuel pump, MAf and fuel pressure regulator were my thoughts but idk.
thanks
BTW before I forget, what did the shop did to "fix" the issue.
Also you may consider a burn or cracked ignition wire. You need to pull them all and inspect.
Run a Fuel Pressure guage and put a 100% WOT Load on the motor ( you may need to find a desolate piece of road) and see if the FP drops more then 4-5 PSI.
Everything points to part throttle and IMO tune or MAF related.
55 to 60 psi with key ON
-3 to -10 psi of the above numbers with engine running
When you shut the engine off the pressure should bleed very, very slowly, over a long period of time, not immediately...
