Where to run wideband wires?
I have my wideband from my gto and am in the process of putting it in. I have everything ready to go just about. But I cant figure out where to run the wires from the sensor. As in where to come through the firewall. The gauge its self will be going on the pillar. Thanks
So you're putting it into an fbody?
Just on the passenger side firewall, behind the PCM, there is a grommet. Take off the kick panel and the other panel underneath the glove box, just cut a hold in the grommet.
or drill through the firewall
I have an automatic and was just wondering if I can route it the same way, If there is a spot under where the shifter and stuff is?
Run it up around the shifter opening in the trans tunnel. What I did is remove center console and the rubber boot that screws to the trans tunnel. I then used my dremel to grind a half-moon slot at the drive side front of where the boot mounts (there's a low spot where I made the slot)and take the edge off the slot so it doesn't cut the cable. You want to grind the slot up to the outside edge of where the rubber boot mounts, then when you re-install the boot it should fit snug against the cable.
![](https://sphotos-b.xx.fbcdn.net/hphotos-snc6/297006_2137322804233_2454642_n.jpg)
![](https://sphotos-a.xx.fbcdn.net/hphotos-snc6/305185_2137321524201_2224350_n.jpg)
Keep it out of the way of the idiots "Hey! What's this do???"
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash4/293914_2137320324171_7498114_n.jpg)
Do the automatics look the same on the trans tunnel as the manuals....as in places to run stuff. Would take mine off and half a looksie but its like 20 degrees and snowing out now so no ambition at the moment.
I've got the ngk afx going in....so I wonder if I can just run the wires out of the front of the center consul area along the floor and find somewhere to mount everything
