what the hec?
Any help would be appreciated.I thought my engine was blown (headgaskets ,pistons, rings etc..)I had a rough idle and it was making some nasty sounds .I had done a comp check and it came out lower on the passenger side like 150psi but I did it on a low battery.Well after sitting in my driveway since september I finally fired her up again yesterday after a oil change and the knocking sound coming from the engine before was quiter and the engine wasn't shaking any more than normal I did however got some light smoke from the back of the engine and it smelled like water and my eyes stung and started to water what do you guys think it is a blown exhaust gasket I have atap but no laptop yet thanks in advance
You may have a blown head gasket. It could be getting in the oil and the combustion chamber. The dexcool is some nasty stuff when it burns. It has a sweet smell to it.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
You can still have a blown head gasket and still make good oil pressure, I've had it happen. Id try a leak down test on the cylinders instead of just a compression, it'll tell you more without all the other variables that can come into play. You can buy one for around 75 bucks or even make your own...just do a search on like yahoo and there is a couple sites that'll tell you all bout them. Just make sure the cylinder's at TDC or the valves won't be closed and the air will just rush right out.
Headgasket= knocking????????????
Sounds like internal noise. Try this:
Warm up the car
shut it off
unhook # 1 plug wire and start the car , does the noise get better, does it get worse. repeat this on all 8 cylinders. If unhooking a wire causes the noise to go away then its likely a bearing, if it get worse then its likely piston slap, cracked skirt, ring ext.
Did you get any water out with the oil, after sitting it should have come out water first then oil. Try pulling the plugs are any wet of damage?
Warm up the car
shut it off
None of the plugs were damaged and there was no water that I noticed in the oil or oil in the coolent.A few of the plugs were dark though and smelled like gas (runnin rich??)I'll try to do a leakdown test and the plug wire thing later this week and see what I find.Oh and I also heard the sound was louder from the driver side,almost sounded like an extreme kind of exhaust leak
