Why does this happen
any more. Then it started happening again. Then I lost all electrics.
Turned out to be a loose connection on the negative terminal. Tightened
that up, trip odometer doesn't reset anymore.
Also, yours is probably doing this too, but fwiw, everytime the trip would reset at startup, the needles did a full sweep across the guage, like someone had hit the reset button on all the guages.
TSB about needing to replace instrument clusters
and fix them under warranty if they didn't have too.
Also odd that if it is just a loose connection why is
it so common on 99's and not seen very often at all
on the others.
Not saying the battery thing didn't work, I'll guess
I'll find out sooner or later.
My cars sits for days or week at a time and fires up
with no problem. We had a two week stretch with
the high under 20 degrees.
