Help with stuck intake.
I have not done this before and I really don't know how much force is needed to remove it from the top of the motor. Are there certain pry point I need to take advantage of or maybe a hidden bolt or something I cant see?
I have looked at the write up on this forum (ls1 to ls6 intake swap) but the information it gives is kind of limited. To bad the one video that seemed to be useful no longer works. I have taken full advantage of the SEARCH function and can not find anything else that would be useful.
Any pointers will be greatly appreciated.
Thank you
Thank you
Lift up and then pull.
Hi,it sure is great to have friends...........we all need help and it's usually the things we overlook...don't beat yourself up..... this is a learning curve for all...
Have a blessed day..............jim
Again thanks for the help I already feel welcomed.
Keep messing with the plastic. BUT the lock inside maybe busted. It should not be but anything can happen.
I ran into this and had to cut the line and replace with a dealership unit, it runs at least 70$ maybe more.
You are supposed to push the line into the rail while using the plastic "cam" lock thing and it will basically come off.
IF you cannot do this and want to try, you can unbolt the fuel rail from the intake and mke sure you get every bolt and just lift it enough off to snake out the intake. Do not bend it too much, its not that flexible. You can kink it.
Didn't break it
Bottom of the intake
also the wire for the knock senor was pinched between the intake and the head, the car was giving the code for a knock sensor so I guess I found the problem.
Finally, the reason for removing the intake was because I found coolant pooling in between the intake and head on the drivers side closer to the firewall when operating temp was reached. after removing the intake I realized coolant does not run through the intake. I can not see any visible cracks on the head so I can't really tell where the water is coming from. Could it be a gasket problem? they are squished and kind of worn....
Picks taken on cell phone sorry for the bad quality.
On a good note I found out I already have an LS6 intake
EDIT: What are the "block offs"? Where would the be located?
~Joshua
Update: After a few days of being a bit chilly here in Houston I finally got the car back together and it's running.....very badly but it is running. I think it might be bad gas but not too sure, the gas is about 6 months old but I did put a stabilizer in it before I put it away. I hope I don't have to drain the tank as it has about 12 gallons in it and I don't have a place to put it. A few other things is it needs a tune and and a tune up so all these thing may be contributing to it running so bad. On the upside it is not leaking water and I made it to the store and back, barely but I made it none the less.
All in all I'm pretty excited and will now be looking for a place to get a tune.
EDIT: Can a computer lose its program causing the car to run bad?
