Too late for a cam?
Just looking for some thoughts on putting a cam in at 126000 miles. I know cam and heads should be put in together for best results but my pockets aren't that deep right now. So is it worth putting one in or should I just wait til I do a full build? I'm just looking to get it around the 400rwhp mark she's at 320 right now with cat back, cai and diablo programmer. LT and ory are going on this month. So if it is worth it what cam should I go with for a stock motor? Thanks in advance!
i wouldnt sell the car because it has 126k miles..... if its that big of adeal to you i would just buy a new engine and start from there.
personally i would just wait till you have enough money till you have enough to do everything you want at once.
mileage in my opinion is certainly not a tell-all indicator of the condition of a motor. 126,000 might be the end of the road for a poorly maintained engine and it might be just fine for one that has had regular oil changes.
The LT1 in my car has about 140,000 miles now, still has great oil pressure, i had the valve covers off not long ago to install new rockers and springs, the heads looked like brand new castings because they were so clean from using synthetic oil over the years. When i replaced my springs i used a leakdown tester to keep the valves from dropping and all my cylinders had max of 5% leakdown most were in the 3-4 range. Therefore i would expect the internals of my engine to look and operate in a similar fashion.
I'm planning on doing my cam and heads very soon as well, and if i do tear up the motor, its just going to turn into a stroker ready for a little juice down the road
One of my buddies has a H/C/I camaro with 160K miles 445whp thru the auto (I think?) And a 175 shot on a stock bottom end. Yes he races almost every weekend and takes it to the track at least once a month and that bitch is still holding strong! Invest in some ARP rod bolts and your bottom end will be safe! Also don't just throw a cam in with stock heads.....id at least strengthen your valvetrain a little
I see no reason why you shouldn't. Just use it as a chance to go through the motor and refresh it. A new valvetrain, gaskets, oil pump, etc. will be like a new lease on life for it, assuming the bottom end is fine. You can check to make sure everything is in order now, while adding power. Just don't cheap out and buy the minimum stuff for a cam swap. Do it right, and it will pay dividends later. A new shortblock is only like ~$3,000, so start saving for that if youi're worried and after the cam swap you can switch them out.
My old ss wasa 99 model 156,000 miles.
Longtubes
Y-pipe
tpsi 90MM intake and tb
ms4 cam with springs and pushrods
Lid
m6 car
Dyno tuned 420rwhp 398rwtq.
GO FOR IT.
I have a 98 trans am I daily drive...bout to beat on it like a red headed step child that owes me money
NO offense if your read headed or adopted or owe money.
Longtubes
Y-pipe
Lid
m6 car
GO FOR IT.
