engine swap question.
Old Mar 14, 2011 | 04:35 PM
Red2002SS's Avatar
Default engine swap question.
I currently have a 2002 V6 Automatic camaro. It has 88K Miles on it and it is the 1st sports car i have ever owned.
It currently resides in the garage at my parents house. (recently received a make over externally, new windshield, paint etc..)
Should I swap the v6 out for a v8. If so what are the recommendations as far as engine type, keep it as an auto or swap it for a 6 speed. Any input you may have.
Thanks!
Old Mar 14, 2011 | 07:07 PM
RARON455's Avatar
Well, If you want a V8 then you should put the one that came in them under the hood, Look for an LS1 the engine will fit and computer and such all fit in the right spot,,Expect to invest a ton of time and money, cause Honestly, you will come out cheaper just sellin your car and buying one with a LS1.
Old Mar 14, 2011 | 08:38 PM
the_merv's Avatar
Veteran: Air Force
Not necesarily..it's not hard to install and wire it.
The T56 part will cost about as much as the whole complete LS1/4L60E swap tho..that part wont be cheap.
Old Mar 14, 2011 | 09:29 PM
Hemi2Slo's Avatar
Had a buddie that just went through this. Converted a V6 auto to a V8 T56. Major headaches involved. Lot of head scratching and a ton of labor. Said he'd never do it again. You have to change the k member and everything.
Old Mar 14, 2011 | 09:56 PM
the_merv's Avatar
Veteran: Air Force
Yea..lol..you need all V8 stuff. I did it to a 1998 V6/T5 Camaro.
Old Mar 14, 2011 | 11:25 PM
WSsick's Avatar
You're just better off buying an LS1 car. They can be had for cheappppp these days.
Old Mar 14, 2011 | 11:54 PM
ivan_key's Avatar
+1 on just buying a v8 camaro or trans am, they are all over the place for sale for cheap
Old Mar 15, 2011 | 10:59 AM
Red2002SS's Avatar
does anyone know of a post where someone has done this that has a list of parts?
i doubt id consider swapping it out for a manual transmission just for the simple fact that you have to install a clutch in an automatic car (just sounds like way 2 much trouble)
i know it would require a new rear end amongst quite a few other parts.
but like the 1st question said. is there a list of parts or a website where someone has done this?
Old Mar 15, 2011 | 11:48 AM
RARON455's Avatar
Doubt it, Not too many people would tackle the project, and even few would remember what all it took, and prolly none wrote the stuff down. heres a few for you, v8 front suspension, radiator and all connections, engine with with all hoses sensors harnesses and computer, same for transmission, crossmember, driveshaft, rear end, full exhaust, believe you will need a new instrument cluster to match the ECM, Those are gonna be the big ticket items that will eat your wallet. then there will be all the little surprises. You will be better off getting a v8 car. If the car has a ton of sentimental value then go for it, but expect a money/time eating project.
Old Mar 19, 2011 | 04:03 PM
Thackdaddy43's Avatar
Hey man I am just about to start the same build. All i now from gathering info is wen buying a motor you want to get one around the same year as your car. But i will post my build and parts it took.
