98 ls1 Computer vs 99+
I'm getting ready to get my 98 Camaro tuned but I've heard I would have to get a computer out of a 99 and newer Fbody. Is this true because I really don't want to have to do this. What are the big diffrences in these two computers. ??
LS1Tech Administrator
Received 1,492 Likes
Some people like to make this into a bigger deal than it needs to be. There is no reason why you can't tune a '98, unless your tuner sucks horribly. Yes, it's true that the '99+ will be easier to tune for extreme setups, but for most normal builds the '98 PCM can be tuned just fine.
the 99 pcm is not compatible with the 98 fuel gauge with out alot of work inserting new files into the pcm that apparently neither I or my tuner knew anything about. I wish my car had its stock 98 pcm in it just so I dont have to deal with the gauge issue
Dont listen to this guy^^^. You plug a 99+ 0411 pcm in that car and you're gonna have some serious problems. If you want the 0411 pcm you're gonna have to repin the harness to accept the new computer. I have a 98 car with a 0411 pcm and I had to repin the harness to get it to work. Unless you are going extreme on your setup you dont really need it
A "little budget build" should not need a PCM swap at all. If you're looking at a usual heads/cam/bolt-ons build, then any decent tuner will be able to get your car running just fine with the stock PCM.
Bringing this back from the dead. Got a 98. Just emailed slowhawk, who doesn't want to tune a 98. Wtf. And is also telling me it's no big deal to swap. Just a harness and pcm. I asked about gauge cluster, and fuel level, he said "plug and play"...........wtf
My suggestion is to simply contact another tuner, unless you're planning an extreme setup that will benefit significantly from the swap.
Just a guess but they may just not want to deal with some 98's bricking then the finger was pointed at them from people who don't know about the 98's and it turns into more hassle than it's worth.
Like RPM WS6 said, try and find another tuner.
I have had my 98 computer tuned many many many times including the setup in my sig with absolutely zero issues.
Now I have two buddies who had there 98's brick on them on the first initial tune. Guess I'm just lucky
thanks in advance
I am gonna do this because i am trying to do a 4L80e swap on my 98 Z28 but i can't with the stock ecm because it's not capable to hold another file or something like that for the 4L80e transmission. Was this repinning easy or did it give you a headache? I purchased a 02 camaro ecm and i need to do the repin but after that is there anything i gotta do in order to turn my car back on as it would with the stock ecm?? Any tips and hints be great
thanks in advance
thanks in advance
And thats correct a 98 pcm cannot control a 4l80e.
The following users liked this post:
heavychevy383 (05-28-2020)
taws6m6 hasnt been on in years (sold his car a while back). I remember him doing the swap though, and he said he labeled each and every wire in the pcm connector, and removed and re-pinned them. He said it was a quite a pain in the butt.
Thanks in advance
