hello
Nick G.
True duals? Sweet! Must sound great. Completely stock our cars can run mid to low 13's, with your mods you're probably somewhere around high 12's to low 13's. I'm in the same boat as you, my previous car was a 3.4 Camaro, big diff huh? You really don't have to choose your races that carefully, if you drive properly there is not much on the street you'll have to worry about. You'll beat stock Evo's/STi's/SRT-4's, and stock non-Z06 Vette's. I'd watch out for 03 Cobra's, though and that's the only Mustang you'll have any competition from. Z06 will probably give you trouble also. But of course this is all assuming you can drive. I can't drive well so I gave up on street racing b/c I have no traction on the street and was losing to slow cars b/c I can't put my power to the ground.
Anyways, good luck and have fun with your new T/A. Btw, you've gotta a LS6 intake manifold already, so don't go out and buy one.
on the MAF sense elements and mess up your
tuning, especially if the filter oiling wasn't done
-just so-.
There should be no "chip", perhaps you can get a
better idea from your source of info about what has
been done (probably programming). This might affect
you further down the road if you (just by chance)
happen to get bit by the mod bug and need to tune.
Meanwhile if it doesn't ping, life is good. If it does
(like a little gurgle at the top end wide open or the
bottom end when leaving the light) you will need to
step into tuning (one means or another). You might
want to inspect the MAF and determine whether
1) it's stock (with Previous Owner Mods, it may not be).
Should be dull factory aluminum casting "Oreo" with a
screen. Screen may be removed with few consequences
in a chunk-free environment; no signs of filing / grinding,
no shiny anodized ends, no plastic ends, unless the
"chip" (tuning) was done to properly tune for their effect.
Stock is best. See attached pic for a virgin example.
2) it's greasy (see filter); white glove test on the back
inner wall of the unit, don't touch the wires. Dry is
good and oily is not. A proper air filter would leave
it dead clean.
