What to do next???
S7cam, Fast90, NW 90, ETP heads, subframe connectors, adj panhard bar, koni shocks, bmr springs, slp lid, bellow, Strage 9", full exhaust inc. lt headers and cutout, vfn hood, engine has about 1000 miles on it. Dynoed at 455rwhp 400rwtq.
LCA's and relocation brackets should be here next week. Went with J&M.
Are my fuel rails and pump enough for my power level? I don't know if he upgraded the pump or not. No hatch cut under carpet. It does have 36# injectors.
Also, when the engine was rebuilt before I bought it the shop said #7 was ran lean and that is why it needed tore down. New piston, rings, ARP rod bolts, Melling oil pump, O2 sensors, were installed. I bought it right when it left the shop. He had to have it rebuilt in order to sell it. Now, is there something I need to do in order to keep this from happening again? I don't track the car. All street and car shows. I do get on it. With the cutout open, 455hp, and 6 speed it's hard not to. I wouldn't have $4,000 for a rebuild if it happened so I would like to prevent it. I was going to buy an SSRA for it but got scared when I read about the #7 piston problem and figured I should wait until someone could help me with my upgrade. The car has not had the free ram air mod done. Just SLP lid. I was going to put on the SSRA hoping for another 10-15hp but didn't know if that would put me closer to danger level with my fuel system.
So I have been looking at Fast Fuel rails with line conversion kit, or an SSRA, or a Racetronix fuel pump and wiring harness, torque arm, Strano sways, MGW shifter to replace Pro 5.0. I can't do them all just pretty much one of these. What path should I take?? Need suggestions........
Look in to venting systems for the coolant ports in the heads. You have plugs in the rear of the heads to fit the fast intake. Get those vented again and that will HELP with the # 7 hole getting hot. http://www.kurturbanperformance.com/...or-system.html
Would throwing 42# injectors on just to be safe do any harm?
Ok, so without dropping the tank or cutting a hole, is there any way to tell if the pump is stock if the wires are not visible? Would a fuel pressure gauge be able to show that?
EDIT: I take it this would be the one to get? http://www.ws6project.com/user_stor/...x-fuel-system/
I might give that Torque android app a try. It read it can read IDC. I would like to check the before and after SSRA to see if it makes a difference too.
